VintageGarage
- Joined
- Jan 29, 2007
- Messages
- 8
I have added a spur off of the main A/C system of the house to run cold air to the garage. We live in Houston and heat comes free with every garage down here.
You can not work in a garage in Houston in the summer without A/C just to remove the humidity if not to lower the temperature. I had the unit sized with this extra load in mind when it was changed out recently.
I found that I had to also insulate the thin metal garage doors from the direct solar radiation. In the mornings the sun would hit the East facing doors and drive the heat up tremendously. By installing 1/2 rigid insulation panels on the inside of the doors this heat gain was cut down quite a bit.
Has anyone else out there added a duct from their main A/C unit into their garage? Has it achieved the desired results?
