green.bubbly
Building my house and would like to start working at night inside of it. On my main panel, I have a few light circuits on one side of the panel.
Want I wanted to do was hook up a male plug to one side of the panel so I could use a few of the light circuits by turning on a couple of breakers for the lights. When it was time to leave, I would just unplug the plug to the panel.
The plug would plug into an extension cord running out to my temp pole. So far so good. Problem is that when I plug the plug into the extension cord, it trips the gfci receptacle on my temp pole.
To trouble shoot, I disconnected the hot wire feeding my panel from the plug. All I have is the neutral and the ground from the plug attached to the same bus and it still trips the gfci.
The polarity of the extension cord is correct and the cord works fine if I plug anything else into it. 120 volts between the ground prong and the wide terminal.
Any thoughts other than I should not be running power to my panel.
***edit** I left only the neutral connected to the bus bar and it still trips the GFCI. All breakers are off. ???
