have a compressor but...
tech
keene nh
i have this compressor that i got from a friend because it needs the pump rebuilt.
http://www.homedepot.com/prel80/HDU...E=PROD_META&CNTKEY=storehome/pg_storehome.jsp
but even if i get it fixed it will put out just under what i'll need it to, because it only puts out 10cfm at 90psi and i'll need more than that for the amount of painting i do.
so my idea was to just replace it with this bigger pump, but i don't know if the motor i have will run this pump. my motor is a 220volt one.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_290953_290953
this is where you guys come in... can i do this or should i just buy a new one like this
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_211720_211720
what do you guys think?
cncjerry
western PA
I am assuming the motor you have is 5 hp if so that pump will work very well for your situation otherwise buy the IR.
bmwpower
I think I might go for the IR. Keep the tank and plumb it into your system as a reserve air receiver.
cncjerry
western PA
Yea 6hp will be fine make sure you match your RPM's between the pump and motor by changing the pulley size on the motor.
