Have you ever broken an extension bar?
kartracer55
I have seen the female end of a craftsman 1/2 inch extension break like in vulturej's pic, but the guy had been using it on an impact gun for what looked like eternity, it was pretty beat.
In my opinion, those 4piece 3/8 drive sets go on sale for 9.99, it is a hell of a deal, you really can't beat it.
GDA
Dallas, Texas
Yes. I once destroyed a 3" Cman extension while using it on my IR 2115 in an effort to remove a friends brake caliper bolts.
tsumetai-kokoro
i have old proto extensions that i consider broken- they spring like torsion bars every time you try to use them. so i leave them in my in the trunk toolbox.
i've mangled plenty of extensions otherwise. snapons tend to twist more than shatter so i like that. keeps me from slipping and hitting things. craftsman and matcos tend to crack, split, or lose heads more, usually costing me some knuckle.
all you need to break an extension is a CFR17LFT
tube_guy
Years ago my brother and I were restoring a 1969 VW Superbeetle. We were rebuilding the engine and trying to get the flywheel nut off. The torque spec on the 36mm nut was something like 330 ft lb, and it hadn't been removed in at least twenty years. I was using a SK half inch drive breaker bar with about a four foot cheater pipe. Twisted the drive end right off a cheap half inch extension. Put a SK extension in its place and got on with it. Removed the nut without a fuss.
Scooterfish
Northern Indiana
Kartracer55 "In my opinion, those 4piece 3/8 drive sets go on sale for 9.99, it is a hell of a deal, you really can't beat it."
I picked up the 3/8dr 4 pc wobble on the Cman sale for $12.50:thumbup:
Snap on 6pc set is $148.
Uncle Buck
Kansas
I guess the reason I do not break a lot of tools is in a situation like this I know I would be using 3/4" drive stuff right out of the gate, that might explain a little bit. :thumbup:
tube_guy
The problem is that I didn't own any 3/4 inch drive tools back then. Still don't, even now, and don't really have the work to justify buying them. The cheap 3/4 inch drive stuff is probably no stronger than the better 1/2 inch drive stuff, so it's quite expensive to get stronger. I've broken very few quality tools over the past thirty years or so. That cheap half inch drive extension, which was abused, and one 10mm SK socket which was not. That's all I can recall.
Uncle Buck
Kansas
I can sympathize, I have been there myself years ago. When you aquire a rather extensive range of tools it is easy to sometimes forget that not everyone has the same arsenol at their disposal. Yea, I did used to break a few more tools than I do these days.
engnerdan
Minnesota
I have never broke a brand name extension but I have a couple chiwanese extensions that are mangles. One I twisted the male square end off and the other a 20+ inch I bent using it as a pry bar, heated it to straighten it and did not think about the fact that I changed the heat treat and the last time I used it, it twisted around a good half turn. So it has been retired.
-Dan
sammerdog
West Michigan
Here's my 1/2" showing the square end twisting off....
<a href="http://s384.photobucket.com/albums/oo283/sammerdog556677/?action=view&current=GEDC0246.jpg" target="_blank"><img src="http://i384.photobucket.com/albums/oo283/sammerdog556677/GEDC0246.jpg" border="0" alt="Photobucket"></a>
<a href="http://s384.photobucket.com/albums/oo283/sammerdog556677/?action=view&current=GEDC0244.jpg" target="_blank"><img src="http://i384.photobucket.com/albums/oo283/sammerdog556677/GEDC0244.jpg" border="0" alt="Photobucket"></a>
The stud wound up snapping before the extention did.
sammerdog
West Michigan
....wanted to show 'em life size.
Kidding - got a new camera and still trying to figure the silly thing out.... thought I got it adjusted and the ol battery gave out. Looked around for a fresh couple of batteries, couldn't find any. I asked the Wife why we're always running out of batteries. She had an answer, but I don't think I should list it here.
jerk_chicken
Germany
Yeah, blurry + unresized = wasted bandwidth. I could sort of see something there, but it's also probably the grassy knoll.
jerk_chicken
Germany
The extension was a 1/2" SAE. Your monitor in Germany is probably Metric, hence the problem.
Kev442
Wi
I've twisted plenty of 3/8ths, mostly El Cheapo's, but a couple Craftsman have met their maker reduced down from 1/2" drive. But, no breaker bar needed, I break 'em the regular way!:)
speed bump
Butte Montana
I always wondered about why Germany is on the metric system. The people that I have met with the biggest dislike of the french are German. The metric system is French?:confused:
Doesn't make any sense to me.
T
ToolGlutton
Washington, DC
There are only several countries left in the world that do not use metric system, e.g., Myanmar, Liberia, and the United States.
Uncle Buck
Kansas
The Germans need to take a number after me! I hate the metric system and wish it had never come along! BTW: I also hated the way cassette tapes replaced 8 tracks years ago too if that puts any perspective on the matter! :lol_hitti
jerk_chicken
Germany
Because it was agreed upon as what would compose an international standard. There are exceptions, however to everything, such as bike tire/wheel sizes, car wheels/tires, ratchet drives, and a few other things, as the measurement method became a somewhat even number in inches that does not easily correspond to mm or cm.
However, it looks like you don't know this, but metric is taught in US universities and colleges, with Chemistry, Physics, and related courses, as well as more specific courses above being taught in metric only. They sometimes use non-metric units in order to add complexity to a problem. However, the rest of the problem is conducted in metric.
So the US is a metric country, with some crossover, however. Some things will likely be leftovers, such as miles on roads, but moving over to metric is a good thing. Hell, I have never owned SAE tools and never needed them.
sk farmer
nd
tube guy, i disagree. 3/4 inch stuff has a lot more material than 1/2 inch. i can't explain why but a similar length 3/4 beaker alongside 1/2 breaker easily takes off things the 1/2 can't. i would say it might be more tool weight plus being more ridgid -less flex than 1/2. even a mid grade import would be much stronger than good 1/2. not a tool needed every day but they get the job done. maybe not the hf 60 dollar set even though i have one similar and it has held up well.
T
ToolGlutton
Washington, DC
Man, metric is the only language in science, no matter which country you are in. :beer:
If every country is using metric, imagine how many specialty tools we can afford.
stricht8
We only stick to inches beacuse our infrastructure is based on it. Metric is far superior in every way.
speed bump
Butte Montana
The US is very much not a metric country. The only things you consistently see in metric are newer cars and electricity. It was a ***** relearning the units and constants in 1 week for chemistry when doing it in the real world. Its really fun trying to show anyone how to do things in the metric system because almost no one actually understands it even Albertans that are in my Strengths lab section understand english units better than Metric stuff.
speed bump
Butte Montana
Not so much, try doing practical pressure calculations with it, or heat calculations with it, they get to be a pain rather quickly as compared to the english system. Also feet are a very convenient expression of size as are inches compared to centimeters and meters. Also in the english system its easy to tell if you screwed up converting something, I watch people who use the metric system 50 hours a week screw up simple conversions because its very easy to add or drop a zero while doing this stuff.
The metric system is done pretty well for volume measurement though.
stricht8
True that the foot is a practical unit of measurement, but for the most part everything else metric is the way to go. Calculations are a lot easier. Mistakes are made with any unit of measurement. It is a lot faster to measure or calculate anything using the metric system. Most of the rest of the world has adopted it for a reason and a damn good one at that.
jerk_chicken
Germany
Nah, the US is a metric country, with holdovers from Imperial. If you're in practice using Imperial, that means you're simply part of the old way. I've learned primarily in metric since the early 90's in HS, and since then all metric.
