I have a MAC (or is it Matco?) brake double-flaring set that I picked up a while ago, and have just now started experimenting. I need to change out a stripped brake line nut, so I am going to need to cut off the rounded one, replace with a new one, and reflare the line.
Its similar to this setup, just in a red box:
http://www.mactools.com/shoponline/product/tabid/120/p-318973-double-flaring-set.aspx
Problem is, I keep running into a few issues with my flares. The #1 issue is they are canted or uneven, and I doubt I will be getting a good seal. It seems to me that the 3/16" die I'm using is clamping down off-center/and an angle, and I have not figured out a way to make sure it clamps down "straight". I have the correct amount of stick-out, but I'm still having issues.
Any suggestions, or is this issue inherent with the design?
