HD Galvanized Table
Leaky88
Illinois (Temporarily)
I picked up a nice 72” x 28” x 36” HD table today.
Plan was to make it a dedicated table for metal work, grinding, welding etc.
It was painted, showed some rust, good and heavy, and looked like a good candidate.
Naturally, after getting the treasure home I noticed some peeled paint and realized it’s Galvanized.
Believe I know the answers, but I’ll ask.
Would it be safe to cover one end of the table with a plate of non-galvanized steel and weld on it?
Do I have any other options?
Thanks
cvairwerks
Within hearing distance of Texas Motor Speedway
Welding with galvanized anywhere close to the HAZ is a no no without proper PPE. The vapors off of heated galvanizing contain highly toxic chemicals. I'd just get some stainless bent up to cover the portion you want covered and simply bolt it on. Or you can order a top from Uline or similar and trim as needed.
L
Leaky88
Thanks.
Not interested in a dirt nap. Just trying forgo cost of making a table
I certainly did not do my due diligence.
I know galvanized requires a certain primer or prep prior to painting so paint will adhere, but other than that, I don’t know how to determine whether it’s galvanized or not.
Xcursion88
Question...
Is it a wood top with a sheet of galvanized covering it or is it completely galvanized as the top? And how thick?
My suggestion and you'd be time ahead regardless...
If it's a sheet covering wood rid the galvanized sheet and replace with any ordinary steel sheet.
If the entire top is thick galvanized get metal supply shop to give you a replacement top..they can knock holes out if it's extra thick, put bends in it...whatever...and make your new to you table exactly as you'd like.
Xcursion88
Table top is ALL metal. No wood.
Ok...so find a steel shop in your area...give them dimensions and where you'd like mounting holes to be and you get a hunk o' table top real cheap exactly as you'd like it to be.
My .02 cents of good old cash.
P.s.
I echo again...You'll be miles ahead than if you try ahd paint...use an overlay...etc.
PCustoms
VT
I'd weld on it as is, top should not be getting hot enough to be a concern....
Post a pic of this thing!
L
Leaky88
Best pic I have right now. No one has been around to help me download it yet. Seller and I loaded it and it was NOT light. Don’t want to do anything to make the 6:00 news.
L
Leaky88
Better table pics.
