HD or lowes kit sheds
bagged89s10
CT
Does anyone have a home depot or lowes kit shed? These are under $1000 and seem decent. I know they aren't built as nice as some sheds and don't use 16" on center studs. I just need a place to the lawn mower, snowblower, garden tools, and kids toys.
chruler
Vermont
I have a plastic panel HD shed that I built almost 20 years ago. It has stood up really well.
The key ingredient is the floor. DO NOT use the suggested floor kit for these sheds. They were 2 x 3's on 16" centers with 1/2 plywood. Real mushy.
I used 2 x 8's on 12" centers with 3/4" treated ply. The floor still feels like concrete 20 years later and of course has helped preserve the inside of the shed.
I also treated the floor lumber with wood sealer and every time I made a cut, painted the end with sealer for longevity.
The sheds themselves are all pretty good, but a great floor will help keep it square and sealed from the elements. Do the job once!
bagged89s10
CT
Thanks for the tip.
vette66bob
North Jersey
I have had some experience with this type of shed, first depending on your climate situation and location. They are not long lasting. Second, in the north east if you are near PA. The Amish make a very nice assortment of all types of sheds and if within reasonable distance they can drop them directly on you site. Third, I have found building your own gives better results. Of course time and skill play a big part in your decision. As always no matter what size you build it will never be enough.
stikman56
Your picture in the middle, -that shed from Lowe's I think is the best bang for the buck. Huge loft, lots of space. They built those at work forour wash crew to use. Good ,for the money.
I decided to build my own again, it can to match the other buildings as I have siding and stuff from the house build.
kaymccampbell
Upstate New York
I have 2 sheds. One we designed and built to take a few tons of mowers, implements, Dingo. The other we bought from an Amish shed dealer designed to hold a few tons of renters' ****. Both are dandy. Both cost about the same. Doing it over, it's a toss up.
I did find the Lowes, Hd shed kits pretty crummy. Floors are thin and weak. Siding is usually some substandard chipboard t111 stuff. I swear they get the things after they have been sitting unassembled in the rain for several years. I rejected several before just paying the local shedco to drop an assembled Amish one off.
bagged89s10
CT
My original though was to just build one myself from scratch. I need to price out materials on something like an 8x12 with 16" on center studs. I can probably make a door to save money, or find one at a habitat restore. I kind of want a shed now but I think spring is when I'll actually have time to build one, kit or from scratch.
jwhcars
Central PA
I went with an Amish built 12x20 shed. It is well made, I would check and see what you can buy in the size that you need.
I bought my shed from Pine Creek structures in Pa. They also have locations near you.
Gummi Bear
Sunset, Texas
I am completely sold on the metal sheds.
Mueller offers several DIY shed kits. I've helped put a couple together, and it is the route I will go if/when I need another shed. I'm guessing that there are other metal building companies similar to them in other parts of the country.
http://www.muellerinc.com/steel-buildings/building-types/backyard-buildings
Check your local building codes to make sure they are OK, and some communities even have aesthetic regulations.
I went to the woods because I wished to live deliberately - Thoreau
tfinniii
Balto., Md.
With a plastic shed make sure you have flashing turned up inside and then out over edge of wood base.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
My wife and I put one of this style together for my parents. Biggest ************* I ever ran across. Only a couple of studs on one end and the shelf is what holds the wall from bowing in and out. No treated lumber. Just standard 2x4's for the floor and some 1/2" plywood. Wall studs are 2x3's and crooked as can be. Roof is 3/8" IIRC, and the walls are 3/8" stamped OSB. For the price, you can build one better.
jhelrey
MN
For what it is worth... I built a 10x12 shed a few months ago.
My base is 2x6 green treat with nails in ends and hangers. 16 on centers
Walls are 2x4. 16 on center
All roofing was free. (Neighbor owns a roofing company. Once bundles are opened they cannot return. Nicer than the roof on my house)
LP Smart Side Panels found for $17 a sheet on CL new.
I built barn doors and made them 7x7. I built it for a few specific items.
Also 8 foot walls, no clue on roof pitch. I just designed my own trusses. Plenty of height for the loft in it.
Any many more overkill items..
I'm into it for $1300.
Looked at a few kits and just shook my head
383 240z
Findley Twp. Allegheny Co.
ALL of the Lowes/HD sheds are WAY over priced. If you've got a few tools and a little talent, you can knock together a shed quick. Very easy for one guy to put up a 10'x 14'.
I would use deck piers to get yourself a LEVEL starting point. Just needs to be VERY square and Very level. Some PT 4x6's on edge will do for that. The piers will get you up off the ground, IE out of the snow, key to making the bottom edge of your siding last!!
Now put some joists in there PT 2x6's 16" OC covered with 3/4" PT plywood.
Lay out your short side walls ad stand them up. You can sheet them before you stand them up OSB is fine for this. Make sure they are plumb and square!! Lay out the back wall, in 2 sections if your on your own, stand them up and plumb them. Now the front wall with your doors framed in, square, sheet, raise, plumb.
Roof can be simple angled shed roof or you can build some simple rafters. For the shed roof, Make the front wall 24" taller than the rear. 2x4 rafters 24"OC. Lay up 1x4's for purlins and cover it with metal panels. If go for a shingled roof, 16" OC 1/2 OSB tar paper, and shingles.
Then you can side to match your home, or skip the OSB on the walls, and use 4x8 sheets of siding.
mmb617
PA
I'm going to have to agree with those saying that for the same money you'd spend on a kit shed you could build one that's much sturdier from scratch.
I've looked at a few of those sheds just for giggles and they are really cheap made. Sheds are really easy to build from scratch, and you have full control of size, roof pitch, number and size of doors and windows, the whole nine yards.
James-W
Southeastern Wisconsin
Building it yourself from scratch is the best idea, although it will cost more than if you build a kit. But the important thing is, you will have a MUCH better shed than you would if you go with a kit.
jhelrey
MN
Your other option is to look for one on CL for sale and move it yourself.
I would have but they all required too much repair to justify but there were some but too far away.
rayra
Escaped from Los Angeles
Needed a shed at a mountain house several years ago, shopped the pre-built wooden sheds pretty heavily. Most at Home Depot and Lowes were pretty sturdily built, with about a 1/3 price premium over what it would cost to do yourself. Delivery issues and costs and not quite finding what I wanted in size shape and arrangement led me to build it myself.
Built a 6'x10' with a sloped 8'x12' roof, board and batten exterior, mixed and poured my own slab and had 3 doors, one whole end opened up. Total was about $1500 in ~'06
I made a 1/4"=1' scale balsa model of it first
tx_mike
Richmond TX
I am working on one now that is 10x12. I looked at the kits as well and figured i could do better. I built walls 24 oc and my floor is 2x4 on 12in center. 3/4in flooring. I am in for about $1000 now and think ill finish around $1100 to 1200
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Ironhorse74
MEMBER EMERITUS
The Pacific North Wet
I built a HD 10 x 12. I was not impressed. The instructions really left a lot to be desired. Fit was not that great. The way the raters were assembled was slick however. All in all I would rather do one from scratch.
Brad
bagged89s10
CT
That's a nice building.
sharpe427
I built a 10x12 from Lowes 2 years ago--was absolute junk. I ended up spending way too much correcting errors in design than if i had started from scratch. Wall studs were 2x3's; so crooked the nail line outside looked like I was drunk when I did it. Floor was 3/8's strand board and joists were 2x4's. FWIW: I would NEVER buy a wooden shed again, but the metal ones seem a lot better, especially for utility stuff like lawn mowers, dog house, etc...
38Chevy454
Cincinnati, OH
I have to also suggest to just build it yourself. Look at how they are constructed, then compare to regular bldg construction. Learn and take notes/pictures. Then just design your own. You can do it. Make the base an even 8x12, or 12x16 or something to make the measurements even divisible by 16 inch centers and minimizing the cuts and special fitting required. I bet you can build a better shed for less money than the pre-made kits.
Also keep in mind, it is a shed, so just build it good, not as a bomb shelter.
jimgood
Marshall, VA
I did some calculations based on a 12 x 12 structure, gable roof with 1' overhang on all sides:
8' stud walls on 16" centers
2 x 6 floor joists on 16" centers, perimeter joists and joist hangers
2 x 8 ridge beam
2 x 6 rafters
23/32" ply floors
3/8" ply roof sheathing
T1-11 siding
Priced materials at Lowe's.
Total comes to $1146.47, which is just under $8 / sq ft.
I forgot the gable studs and sheathing to cover the gable ends. And this also doesn't include door framing, hinges, windows, piers (or any other footing), shingles, nails, exterior trim and I'm sure other stuff.
So, I'm betting you can build a nicer shed whatever size you want for about $10 - 12 / sq ft.
Edit: I also did not price the pressure treated lumber for the floor joists. But that will only add about $13 to the overall price.
bagged89s10
CT
2 x 8 ridge beam
2 x 6 rafters
23/32" ply floors
T1-11 siding
Nice calculations. Plus a a few bucks for roof shingles. Hoping to build one this spring.
Barnabas
Raleigh, NC
I got the Lifetime Products 60095 shed. 10' x 8'
http://store.lifetime.com/products/blt/pid-60095.aspx
They make several sizes and even have extension kits. You can get the door on the long end or the short end, or both.
I have seen great deals on them at the warehouse clubs, but I wanted this size, and eventually bought directly from their website.
It took me two days to set it up by myself. Great instructions and the screw/parts bags are clearly labeled.
Mine is on a concrete patio, but they do give you plans on making a foundation.
Great design, quality parts, water tight, will never rot.
jgorm
San Diego
100% agree. It wont even take longer to build it too. I build this in a about day with 1.5 helpers.
Painting inside is always crazy!
Krauts
Wisconsin
Have you looked into the tuffsheds that HD sells? Prices include installation. Metal frame base, real 2x4's and 16 on center. Mine was assembled in two hours. I would've built myself but it would've taken me several weekends of putzing around.
TonkaJoe
Southern ON, Canada
For that price why not spend the extra bit of money and go with something like this? mine is vented, and sitting on a concrete pad.. also has a 1/2 loft inside for extra storage. Stores my snow blower, lawn mower, garden tools, lumber, etc, and still has plenty of room to spare. It helped me organize things much better, and got everything out of the garage that didn't need to be there!. I only went with a pad because I didn't feel like dealing with un invited critters :thumbup:
My build thread: http://www.garagejournal.com/forum/showthread.php?t=306497
CJ7VFR
Central New Jersey
... in the north east if you are near PA. The Amish make a very nice assortment of all types of sheds and if within reasonable distance they can drop them directly on you site.....
This is what I did. I live in Central NJ, and my shed is from a place called Pequea. They are located in Lancaster PA, and they were very accommodating with the things I wanted for my shed like taller walls, 6'-6" high doors, gable and sofit overhangs, larger gable vents and roof venting, and a 4 foot wide loft at the back of the shed.
They built it, painted it with my custom colors, and delivered/placed it dead center on the pad I made for it. My pad is made from pressure treated 6x6's with 3/4 crushed stone inside the 6x6 frame.
My shed is 10x16, with all pressure treated flooring, 16 inch centers on all the floor joists and wall studs, as well as 16 inch centers on the roof joists.
I am very happy with my shed, and it is built very sturdy, just like a small house! The last thing I have to add are gutters and some more landscaping around it and it will be done.
Here is a picture of mine. I would recommend Pequea to anyone looking for any type of out building.
Jim
McSpike
Montana
Not much to add other than to agree that building one from scratch is cheaper, and better constructed. I built mine (as was suggested earlier) 8x12 with 8 ft walls so I didn't have to make very many cuts. Where I am, anything under 100 sq ft doesn't require permits, so 8x12 is a perfect size. I just built mine on two pt 4x4 skids sitting on a gravel base, then a normal 2x6 frame with 2x6 stringers 16"oc and standard decking for the floor. I used 4x8 siding sheets for the walls and framed it with 2x4 16"oc. Built my own simple rafters with 2x4 24"oc and standard osb roof sheeting. All in for less than $1,000 including door hardware and paint.
When I built it a several years ago, I used 3-tab asphalt shingles. A hail storm two years ago got the insurance company to pay for a new roof for the house and the shed. When I redid the roof, architectural shingles are now cheaper (at least here) than 3-tab, so the shed roof now matches the house. The wife matched the paint on the shed to the vinyl siding on the house.
bczygan
DETROIT! Arsenal of Scrappers
First question. What are the kids toys? What garden tools?
Make a list of exactly what you need to store. Then do a layout of how to access everything. Decide if you want future space available. Then wrap that with a structure. Now you have the design.
Once you know exactly what you want to store, you can size the shed.
Next step is to check your zoning, and zoning rules. This will tell you what you can build without a permit, and where you can put it on your lot.
Then you need to decide if it will be a temporary or permanent floor/foundation. Tax rules and building rules for foundations will give you your options here. I prefer a permanent concrete slab, but sometimes that is taxed differently and requires a foundation. Check your requirements. Another consideration for the floor type, is how steep the ramp will be to access the shed.
Once you have all this info, and have made decisions on floor/foundation, then style is the next question. Do you want to match, complement or contrast with the house design?
Now you are ready to make a thumbnail sketch of what you are going to build.
Some design tips.
Make it a module of your building material size, IE 4x8 sheets of OSB or plywood sheathing. And make that sheathing module work vertically as well.
I also prefer steep slope roofs. 12/12 is easy to stick frame. It sheds snow and rain very well too. Where are you located?
And an overhang all around helps protect the walls. I sheathe with OSB and cover with vinyl siding, but there are cheaper methods where the finished siding is the sheathing. I like full 2x4 framing with a double top plate but you can use a single top plate if the wall framing matches the joist spacing. And 24"o.c. wall studs are fine for a shed.
Prepare the site so that all organic material is removed and a pad, or base is installed that keeps water away from the shed and gives a stable base for it.
I like to frame the ceiling with at least a 4x4 opening for access into the attic. And another way to access the attic is from an outside door in the gable end. For more attic volume you can use a Gambrel roof, but consider how the style of that works for you and the fact that is is more difficult to frame.
Use sill seal, treated lumber for the sill plate and everything below the sill plate if you use a wood floor system.
Consider a window, glazing in the door, or a skylight for natural light.
Make the door bigger than you think you need.
I like 3 tab shingles and use aluminum edge metal and #30 felt. There are more advanced roof sheathing materials than OSB available as well as other options than felt.
The style of a shed is not just in the configuration of the masses, but also in the details of how you trim it out. All buildings are just boxes, with different detailing. Choose and size and locate your door and window(s) to reflect the style you are using.
To find out exactly what it will cost, do a spreadsheet. List every item needed.
Excavation and site prep. (Pad).
Foundation and footings (Or skids) Don't forget concrete formwork and anchor bolts.
Framing materials
Trim lumber
Metal brackets and connectors
Sheathing materials and siding (If included)
Roofing materials
Windows (Or skylights) and doors
Nails (Rough and finish) and staples
Caulk and paint
Sill seal
House wrap
Electrical?
Bill
bczygan
Floor framing.
Floor elevation is always a balance. You want to keep your wood framing and sheathing of the walls above surrounding grade by at least 6 or 8 inches. On the other hand, you want to keep the finished floor level as close to grade as practical, so the ramp for access is as low as possible.
This is true for a concrete slab, and even more so for a wood framed floor.
Because of this, I really dislike the two most used methods of floor framing. The first is one where you use concrete support blocks and run beams from block to block. Now, you can minimize the height of this method by burying the blocks almost completely and running the floor joists from beam to beam with joist hangers rather than putting the floor joists on top of the beams.
Some people lay down skids and then build a floor framework on top of them. This adds height that is unnecessary as well. If you start with the floor sheathing, and determine what it will span, then you have the spacing for the members needed to support it. Most sheds have OSB or plywood floors. I prefer treated 3/4" T&G plywood. This will easily span 16" o.c. joists, or a 14 1/2" space. If we carefully prepare a gravel pad for the shed, compacted and level, there is no reason we can't use the skids for those members. Using 6x6 treated lumber, spaced at 20"o.c. we have the same span for the floor sheathing. Run a treated 2x6 across the ends of all these members on either end and you have a floor frame that is also skids, without adding to the height. And frankly, you could do the same thing with 2x6 joists at 16"o.c. Joists OR skids on gravel, it's all the same. No reason to have 2 layers.
Bill
raffaelli
I have a Home Depot 10x12 wood shed. Been in the yard for a couple a three years now. Looks like it was just built. Could not be happier with it.
It sits off the ground on 9 tubes.
tfalk
Somerset NJ
A couple of years ago, I assembled on of the Handy Home Products 10x10's from home depot. Complete ****. 2x3 walls and roof framing. Doors warped and would not close correctly within a year.... For the extra money, build one yourself with 2x4's, it will last a lot longer.
schmitty8225
Orlando
I bought this one at Home Depot for $150 and some change originally $1200. Had to build the floor.Went with 2X6 PT and 3/4 PT plywood. 16" on center and cross braces. The fasteners were terrible so I replaced all of them with my own. Some bolts were not threaded, screws never had a PH put in, or just poorly machined screws. Doors and ridge cap were not secured when I took the picture but I get the idea.
willf650
I built two of these sheds, one 8x8 and a 10x12. Neither are that impressive as a structure. The siding panels are actually structural with these kits.
The ones I got came with a floor kit which was treated 2x4 but you had to supply the flooring. There are no walls to speak of, only toe nailed 2x3 that are basically on 2' more apart to seam the paneling together.
The only purpose these served for me is the fact you simply buy a box and throw it up in a couple hours. If I didn't need instant storage I would build something from scratch.
