HDMI connector replacement
dw1
Ky
Has anyone successfully replaced the end connector on a HDMI cable. My buddies wife broke the connector that feeds their tv, its probably a 60' cable and would be tough to replace, I am looking online, but curious as if anyone has done this and it worked??
Thanks
kd3pc
Northern Neck
Are you sure it is and HDMI cable...??? The "spec" fall apart 50', with significant degrading of the signal on anything over 25'
Picture of the connector and a picture of the cable markings would help to know for sure..
bests
ard
Whatever you do, DO NOT fall for the **** about "high performance" cables.
Best Buy would sell TVs at cost- then steer you to cables: Good, Better, Best...at 59.95, 99.95 and 149.99.... And make ALL their profit on the cable. I'd got to an electronics store or online and pay $4.
bests
I only knew the same thing until i discovered amplified directional HDMI cables.
It actually cost me some labor on a job because i didnt pay attention to the directional note on the cable ends.
kd3pc
Northern Neck
the chipsets that do the amplification and such are vastly different, so choose carefully, if you are pushing HD video or things at HD data rates. The good units get pricey, quickly. And your HDMI devices need to be of similar vintage..
bests
D
dw1
Ky
bests
Yes, it is an HDMI cable running from his Digital- HD cable box to wall mounted Samsung HD TV, this is in a new to him townhouse, cable is minimum 50'
I was hoping not to replace cable, it looks pretty tight at roof line where TV is mounted on the wall.
American Locomotive
Rhode Island
As shown, you can get HDMI plug ends. However HDMI is an extremely high frequency standard, and couple that with a 50' cable (which is really pushing the limits), it may not work.
grantw
Bay Area, CA
Forgot about the powered cables... yeah, maybe a simple end replacement won't work on a 50/75ft cable :(
bests
As far as I know, the chip is built-in to the cable.
And I used the wrong word.
Correct word is active.
kTHREE
MN
Anything over 50ft, HDBaseT.
I don't know why anyone would bother with a long *** HDMI cable.
#1, it ***** to pull
#2, repairing ends *****
#3, uhh did I mention HdbaseT
D
dw1
Ky
O.K I went by there today and measured, it looks like this is a 50' cable (I hope) I guess I will get up in the attic and cut the cable and use it to pull a new cable in. The cable that is in there was working fine, the picture was good.
prostreetamx
Las Vegas
https://www.amazon.com/dp/B01CU9SHOO/?tag=atomicindus08-20
I used amplified 50 and 75' hdmi cables in my new garage since coax cable no longer provides a cable signal that a tv can use without a box at every TV. I plan to put my cable box, DVD player and security camera monitor inputs at one location with a hdmi switch and hdmi 4-way amp to feed each TV. Got one connected so far and the picture is just fine. We run 50' nonamplified cables a lot for trade shows as well as a few directional cables. We break the ends off a lot when the lay carpet over them or you try to bend the really think jacketed 50'ers. I ran the cables in my garage in a way that they can be easily replaced if needed.
Instead of replacing just the end it might be easier to cut off another cable with a good end and splice the wire itself. You will want to pay attention to the shielding for each set of wires inside.
reader2580
Minneapolis, MN
If you haven't done this yet I would install two cat 5 or cat 6 cables instead. HDMI can be run over the cables with a little adapter on each end. The cheap adapters require two cables while the more expensive ones use one cable. The cheap adapters I have used have been rock solid. The more expensive powered adapters have been problematic and require periodic power cycling.
Commendatore
Central NC
Use the dead cable to pull a string. Then use the string to pull a new HDMI and 2 runs of cat5... then leave the string just in case.
prostreetamx
Las Vegas
50' isn't that far for a Trade Show booth where you want the same display on several TV's. Once you run the cable under carpet and back up a display wall in a 20' or bigger booth, you eat up 50' pretty quick. Pretty much the same issue in residential applications where you want to run the output of a single source to several different monitors. I can watch my BlueRay player and other video sources from my main TV location at almost every TV in my house as well as my security cameras. I have HDMI supplied wall mounted monitors located in several key locations also. They also have a coax input that is pretty useless since cable can no longer be selected on your TV without a box at every location. In my case I have a few boxes that I can split the outputs and send the signals over HDMI. I also have a channel modulator so I can create channels to piggyback on the existing cable but the resolution is not nearly as good as HDMI. In my new garage I ran cables to 4 future location since I have not decided where the best location for a TV yet. I haven't given much thought as to where I will be spending most of my time in my 30x38' shop since it took so long to build. Only 1 final inspection away from moving all my junk in to see if it all will fit.
D
dw1
Ky
I ended up pulling a new cable and all is well. It was a 50' cable. Thanks for the heads up, one end was marked "HDMI" and the other end was marked "TV"
Picture is good and everyone is happy.
