HDPE work bench top
alan camby
South of Indianapolis, Indiana
Anyone use HDPE over the top of their wood or steel bench top.
I have a few work benches with 3/4" plywood tops that quickly have become stained with oil and other shop fluids. I stained one of the tops with the darkest wood stain I could find to make the top look better.
Wondering if I would regret trying HDPE to cover a bench?
I have been impressed with UHMW while working in a factory but wonder if the HDPE will hold up as well.
I used to own a Argo brand AATV (6 wheel vehicle) and the HDPE hull and skid plate was very durable.
Menards has sheets of black HDPE in 1/4" and 3/8"
http://www.menards.com/main/p-2246284-c-14048.htm
http://www.menards.com/main/p-2246285.htm
What do you guys think?
1/4" or 3/8"?
Menards has the 1/4" in stock. The 3/8" is quite a bit more $ and has to be ordered.
thanks
MFolks
Springfield Mo.
If it were me, I'd go with the 3/8" thickness. You'll probably need to mechanically mount to the old bench top with screws & nuts. Maybe either countersunk screws, or counter bored holes, for recessed hardware. HDPE is slick, (kinda like Teflon)so most glues won't bond with it.
A
alan camby
I have had good luck using elevator bolts to fasten my plywood tops down.
They leave a very nice smooth top while still providing a good capture of the material. Think of a carriage bolt without the dome head, the head is flat.
sublimate
Colorado
I many applications HDPE is pretty slick, on par with PTFE (teflon).
Will your workpieces slide around as you're trying to work on them?
larry_g
oregon
I have worked on some HDPE tables and have a chunk on my toolbox. It will scratch and gouge fairly easily and then collect dirt to look bad. It is a great top if your working on stuff that you do not want to mar with a harder top or if your working with precision surfaces. It's good if you need it but not suitable for doing heavy auto parts on.
lg
no neat sig line
paranoid56
San Diego, Ca
thats a real cheap price for HDPE, i wish we had one of those stores near us, even from my plastic mfg i cant get it that price :lol: is that smooth or textured hdpe?
Voi
Western South Dakota
When I scroll over the picture on the two links it looks like the generic version of Starboard XL (I'm guessing it's not the real stuff at that price).
If it is, both thickness will consist of a foamed HDPE interior laminated on both sides with skins of "solid" HDPE. This is very similar to Sintra, Celtec and other PVC sign boards, but made from HDPE. It is not the same as cheap foam sign board you can buy at craft stores. These are much higher quality products.
My point is that the exterior skins on both sides will be the exact same mil thickness and basically offer the same degree of protection. Just the foamed HDPE interior will be thicker.
If I'm correct I would just go with the 1/4" panel, assuming it will lay flat as well as the 3/8" panel.
I should also add that these materials are only rated for "incidental food contact" (which I think basically means no chopping) because the outer skin is somewhat easily punctured. This technically means it won't be as suitable for a work bench cap but I wouldn't rule it out based on that. I've made numerous jigs, etc. out of Celtec and it can take a bit of abuse.
I'm making some educated guesses about this Menard's product based on a CGI. I'd go look at them closely in person and see what you think. It should be pretty easy to tell.
rmmiller
Kennewick, WA
We just finished installing 42' of HDPE counter tops on our counters at work. We went with 1/2" thick just for durability and to minimize any chance of warping. It's worked out great, the black looks good and the oils clean right off (we're a hose shop, hydraulic and industrial).
This is one of the counters we have in the showroom, it's 12' long and there are two of them. We also have three six footers in shipping and receiving, all have seen a lot of traffic and are holding up very well, much better that formica!
Stillboardin
Stanwood, WA
Don't mean to hijack this thread but I had a little freak out moment when I saw this picture. Something told me I knew where this was. I clicked off the thread and it was bugging me so I went back and looked again and then looked at where you were from. Kennewick. I grew up in Richland.
Weird how something looks familiar to you.
Back to normal programming.
