OctaneMotorsports
Quick question for you engine builders and other knowledgeable people;
I am re-doing the headers on my Formula Veerace car (sandblasting, re-painting, full header wrap). The engine is a modified VW Beetle H-4 air-cooled engine from the 60's with racing exhaust, which is basically a set of headers with a straight pipe out the back. The key with these engines is reducing temperatures in the engine compartment. The lower the temperature, the most horsepower you have. The key is to try and reduce or eliminate the engine losing power as the race goes on and the engine compartment gets hotter.
I'm going to the race shop today to buy new header wrap for it, my question is which color will (in theory) result in lower engine compartment temps, white or black? I plan on wrapping the entire exhaust system and some other hot areas as insulation. I figure black would retain heat better but I figure I would get an expert opinion before I do this, thanks.
The white REFLECTS heat from the sun while the pigment in the black absorbs it. Let me know how well it works with the torch.
