TX63CONV
I am wiring a 69 mustang and have an issue with my headlights. I think I have voltage leakage to the two inner high beams.
When the outer low beams are on, there is a faint glow on the high beams. This is all new wiring, new high beam switch. I drilled two new holes into the core support for the ground wires on each side. I was able to ground my battery and get 12.8v at each screw so I DONT THINK it is the ground to the body.
When I remove the ground from the drivers side of the body, the high beam on the psgr side comes on and vice versa.
Is there a way to systematically check where the issue is?
