Headliner Adhesive
SRU1436
Bay Area, CA
I need some help, I’m trying to remove the factory headliner adhesive. I’ve tried goo gone and 3M adhesive remover and I am having no luck. The 3M adhesive remover was recommended and was told it was really good, no such luck.
Do any of you have any recommendations? I don’t want to grind on them and want to keep the original paint if at all possible. See attached photo.
Thank you, Matt.
MattVette89
SW Chicago
I don't have experience with headliner glue specifically. But I've removed other adhesives. Have you tried a heat gun with a plastic razor blade? Or a pinstripe remover wheel?
SRU1436
Bay Area, CA
I haven’t tried the heat gun and plastic razor blade, or pin stripe remover. Good ideas, thanks.
CTyankee
CT
I didn't know headliners were ever glued directly to metal. I do the know the stuff is sticky and a mess to try and clean up.
Leaflessshadetree
Don't ask.
I have not done this on headliner adhesive.
Get a cotton towel (or rag), and a clothing iron. Press the towel to the adhesive with the iron. Hold long enough to soften the adhesive enough for the cloth to "absorb" it. Let cool slightly then peal it off.
(Wax paper between the iron and towel if you want to keep the iron clean).
SGKent
Citrus Heights CA
3M spray is a slow process to remove. You will lose paint if you try any chemical strippers. I know one fellow who used a DA with finer and finer paper so he didn't lose the paint. Most people give up and glue back over it, or scrape and sand it off if they want it gone then repaint. I won't vote on the steam method because I haven't tried it but typically 3M rubber adhesive used in upholstery work is not a thermal glue.
Bill Bowman
Metro Chicago
Typically, they used a "hardboard" or "doorcard" which was either covered with a vinyl material, or simply colored to compliment the interior. Personally, I would replace with my choice of board/material and simply leave the old adhesive. Adding adhesive should not really affect the end result. Perhaps an interior guy will chime in with a better idea.
Sometimes, we over think things, when simple solutions can actually be to our overall advantage.
SRU1436
Bay Area, CA
Thank, I might try one of the pinstripe remover wheel.
Thanks, I’ve gotten some good ideas so far.
Ditto what Bill Bowman said. Where is the headliner itself?
I still have the headliner, which i could still reuse if needed.
Actually, Mrs. LS6 recently picked up this little guy up as part of a package with a steam mop:
https://www.thesmartlivingmop.com/collections/all-products/products/smart-living-steam-jr
I was dubious, but it really works well.
Tommy
Thanks for the information.
HotrodHR
North Alabama
That looks like a '60s or '70s truck cab... acetone or lacquer thinner will probably remove some of the original paint.
Not sure why you're concerned about removing some paint... just sand and spot paint and install your new headliner...
like2wheel
On an as needed basis
Since he mentioned in the op that he would like to keep the original paint, seems obvious to me that he doesn't want to run a headliner at all.
Maybe the truck has a little rat rod flavor.
SRU1436
Bay Area, CA
Thanks for the input everyone. It’s an all original 1972 Chevrolet C10. Worse cause is I remove some paint and then I’ll have to touch it up, however, if I can avoid that I’d like to. The original headliner, which I still have is an option too.
DC_Gearhead
Washington DC
Heat gun and plastic scraper like they said above. If it’s gummy you could use one of those rubber wheels they use to remove sticker adhesive.
