HeadLoc construction screws
LeeG
Phoenix, AZ
I was in HD the other day and grabbed a box of FastenMaster HeadLok construction screws. I normally use SPAX, but figured I’d try something different.
The head on these is like nothing else I have seen.
View media item 109810
Are these common in some industry, or just a proprietary design by this company?
Since I will someday have to remove these screws, I did future me a favor and returned these for some SPAX.
50pascals
Rochester, NY
As far as I know, that drive design (used on their wafer head screws) is proprietary to FastenMaster. But I have been using those screws for years, so I have those bits everywhere.
FWIW - That driver / screw combo does NOT strip out - PERIOD.
juddspaintballs
Hedgesville, WV
I used them when I built a bed frame out of 2x12's and 2x6's. All well and good, but I normally use screws with torx heads like Spax and I only had that ONE bit around. I'm moving right now and I went to take the bed frame apart the other day...guess what I couldn't find for a while...
I guess if you had a lot of bits for it that you'd always have one, no problem. But you can always pick up a torx at any hardware store if you suddenly didn't have one on hand when needed.
CraigStu
Blacksburg, Va
Yet another damn screw head design?
KILL IT WITH FIRE!
Nope. No. Hell no.
I am kind of with you here. All we need is one more dang style. But, if these don't slip, let's keep them and ditch torx. I am right now doing a bunch of screw work and I was reminded yesterday that torx hold much better than good ole #2 phillips but they are far from perfect.
Toolfool
Tallahassee, FL
The HeadLoks are designed for heavy use, replacing lag bolts in many situations, out-performing screw specs in other situations. They're not made in smaller screw sizes, like #8x1-1/2". I've been using them for years. Screw heavy cabinets to a wall, attaching newel posts to framing, doubling or tripling up LVL's.
_Stang_
They're superior to any lag bolt I've ever used. The structural screw is a much smaller diameter yet with better holding capacity and it drives like butter. Nothing better for hanging shelves, TV mounts, etc. I just used some this weekend for a 1x4 header board to mount a barn door track on.
bamawildcat
I've been using them, and like them. Since they give a bit in every box, I've not been concerned about it.
L
LeeG
Phoenix, AZ
I don't doubt they are good. I just don't see them as being a big improvement on similar offerings from SPAX or GRK that use an industry standard head.
My issue isn't about hanging the shelves, it is about 5-10 years from now when you are moving and have to take them down.
I haven't touched a standard lag screw since I discovered these about 8 years ago.
View media item 98954
