Heat exchanger cleaner
DeeKay
Colorado
Hey guys, I have recently taken over a site that has an air compressor with some really bad approach temps on it's AC/OC. Judging from all the white crustys built up on this thing, it looks like the last guy thought running a sprinkler on it was a permanent solution. Can anyone recommend a chemical that will remove some of this buildup? Normally I clean my compressors with Simple green crystal and a pressure washer but that won't cut the hard water buildup. The cooler is aluminum but is also heresite coated, so I could get away with some pretty strong stuff before getting into the aluminum (I don't care if the heresite coating is ruined)
chinboys
Amazon or supplyhouse. Com sells condenser cleaner solutions.
Do not use a pressure washer.
Just allow the cleaner to its job and rinse.
D
DeeKay
Colorado
I'll be in there with a pressure washer regardless to clean all the other gunk off of the cooler. Just was looking to see if anyone had any experience with a specific chemical that is good for eating up the hard water deposits.
fitter30
Peace Valley,mo
Mineral deposits will be between the fins. Could try to remove the cooler if it would fit in a contractors plastic bag or plastic sheet to make a tub and soak it in vinegar might work.
Firebrick43
West central Indiana
pcmeiners
Vinegar is acid, it will definitely eat the aluminum.
"Looked at there cheat sheet and they have scale remover but I don’t think you want it on aluminum "
Fully agree, sulfonic acid is corrosive.
Your employer needs to get a 316 stainless finned cooler if the same environment is maintained.
D
DeeKay
Colorado
Cooler is 6" thick and 72x60" takes a day to pull out/put back in and we can't be down longer than a few hours at a time unfortunately.
It's not the environment that caused this, its the previous tech being lazy and not cleaning the cooler, Then running a sprinkler on it constantly to bring temps down.
Since this cooler is heresite coated, I could probably get away with a mild sulfuric acid solution, I don't care if the coating is sacrificed as this shouldn't even have the heresite coating on it in the first place.
fitter30
Peace Valley,mo
Sulfuric and vinegar both have a ph 2-3 but that's straight. Minerals would need a acid to remove them. Depending on the tds of the water have seen ac coils turn to scrap in a month or two.
pcmeiners
"It's not the environment that caused this, its the previous tech being lazy and not cleaning the cooler, Then running a sprinkler on it constantly to bring temps down."
I was referring to the environment of having a lazy/inept tech anywhere near a machine.
Hank11
Tennessee
CLR will clean the deposits. Spray on let sit just a bit and rinse several times. The trick is to apply and rinse quickly as the best reaction occurs on contact and shortly after. Wear appropriate PPE.
D
DeeKay
Colorado
Well the Eco Lyme worked decently well, enough to drop my approach temps by 20° which keeps me far enough away from a high temp shutdown. If I had time to do multiple applications and rinses I could probably get all of the scale off but this unit is due for replacement in a few months anyway, this should at least get it through most of the summer. I wish I would have taken before and after pics but I forgot.
