I have a 24x36 (inside measures 23x33) 2.5 still attached garage. 8’ ceiling in about 2/3 of it with a loft above. Loft is insulated from the garage so it’s cold up there. The other 1/3 of the garage on the end has a 11’-12’ceiling. Everything is insulated with R13 and 7/16” OSB. My 2 9x7 garage doors are insulated but do not seal very well. Planning on new steel backed insulated doors next winter.
Currently heating with a 75k house furnace with 2 primitive duct runs along half of 2 walls. Has no problem keeping 70 degrees even when it’s below zero.
I’ve decided on a beacon Morris unit heater from Menards. Because of price and I’m going to vent horizontal separate combustion. I like their concentric kit.
Anyway trying to decide between the 45k and 75k unit. Using LP gas. Heater will be mounted in the back corner at an angle towards the doors. So the high part of the ceiling is opposite from the heater. I have a ceiling fan up there so I think it should be fine.
Say I have the temp at 45 with 0 degrees outside I can turn the 75k furnace up to 65 and in about an hour it hits it and shuts off. This is with 2 runs of duct. But my 75k kerosene space heater will heat it up from 45-65 in about 10 minutes. I think the biggest downfall of the house furnace is not much air rise temp.
As a test I took the duct runs off and put 2 elbows right on the furnace. I have a piece of plywood behind the filter I can adjust to slow down the airflow otherwise it blows so hard you barely get any heat. Without ducting to simulate the heat output from a unit heater the garage heats up pretty evenly but it runs probably twice as long as it did with the ducting to warm it up.
Anyway which unit would you guys choose? Probably keep it 50 degrees all the time and turn up to 65 or so when I’m out there.
The 45k is on sale for 449 thru Saturday. The 75k is 549.
I’m in Iowa. Usually it isn’t this cold but it’s been pretty much below zero for a week. Long post but i just wanted to make sure I have as much information as possible.
Thanks guys. Been lurking this forum for a long time.
