I have a garage that now has an apartment above it that is heated. It is heated by a mini-split system and that makes me nervous in 2 situations.
1) When the temps dip to single digits or below will the mini-split be able to keep up as there is currently no heat downstairs.
2) if there is an ice storm or other power outage then the mini split obviously won't work.
Because of this I am thinking about putting in a propane heater that has no outside power requirements. The downstairs of the building is currently in 2 sections. The entry way, stairs and storage for the upstairs apartment, this is also where the plumbing comes in. Water lines are insulated with heat tape on them. The other section is the garage. But above the garage is the kitchen and at the far end the full bath.
Though there is a big part of me that just wants to put the heat in the garage area for my own good if I need to be over there in February should I put the emergency heat where the pipes come in? Or do I risk the pipes in the full bath freezing because they are then far from any heat source during a power failure?
Thoughts?
Thoughts?
