Need some help with a heat pump. It is a Rudd Ultra series RPQL-024JEZ. It is at my in-laws house and they have 2 of the same units, one upstairs and one downstairs. The upstairs stopped working the other day and they called. Basically the indoor air handler works (fan blows) but the outdoor unit does nothing. I have worked on these before and somewhat familiar with them. Went down there tonight to check it out. Found the situation as they described. They have had issues with it doing this in the past but there ac guy wasn’t able to fix it. But he had figured out if you power off both units at the breaker and leave it sit for 5 minutes then turn one on first then the other it would reset and clear the problem. But alas that no longer solved the problem.
I verified that it has power to the outdoor unit at the control board. It does absolutely nothing. On the control board is a digital display that shows error codes. When the unit is working correctly it displays a 0 when it’s waiting to come on. If you turn the power off to the outside unit while the indoor unit is still on, you get an error code of L I think. But now it only displays a - on the display. Also it has a test button that allows you to override and start the compressor and fan for 5 seconds. I have used this button in the past to test the fan motor. But now that button does nothing. It also has another button that if you press it and the test button at the same time it displays past error codes. It does nothing when you press these. It leads me to believe that the control board is bad.
Looking for anyone that can confirm the displayed “code” is not really a code. I have attached pictures of it and the code list with nothing that looks like -.
