Heat Pump intermittent operation
cj7365
New Mexico
Ive got a Goodman 18 seer unit heat pump, it has the comfortnet thermostat, every now and then, it will say "Check Heat Pump" and of course it wont run, the aux heat kicks in, its happened about 3 times in the last week.
Then the "Check Heat Pump" goes away and it runs normal
Where do I start, I actually wish it would stay off, so I can get a repair guy out here.
This unit is only 2.5 yrs old.
bazar01
Leesburg, GA
Next time you see the same message, go outside and check the unit. If you see condensation coming off the unit like steam, it just went into defrost cycle and during this time, the aux heast kicks in. If not, there could be other issues.
JakeKohl
Greenville, SC
It shouldn't say "check heat pump" if it's just in a defrost mode.
If you've had it 2.5 years and haven't seen this before, I would call someone to do a health check on it anyway. Whatever is causing the intermittant message is probably fairly obvious.
C
cj7365
New Mexico
it was -31 celcius here yesterday .. that's -23 f .. the wife said she might turn the heat on tomorrow .. just say'n
Umm ok, thanks for the help, I know I can always look forward to great responses from intelligent people like yourself.
I am happy for you that u enjoy the cold
C
cj7365
New Mexico
It shouldn't say "check heat pump" if it's just inI have a defrost mode.
I agree with you about it shouldnt say "check heat pump" when defrosting, i have never seen any frost on the condenser,Yeah i need to call someone, but like I said its an intermitent problem
bazar01
Leesburg, GA
Is this the message you see on the screen?
Then it is not just a defrost mode cycle. Self diagnostics is built in to the Goodman unit and the thermostat. Really dcannot tell what sensor/s triggered the fault message, I apologize that you cannot diy this case. Only qualified service technician can diagnose.
C
cj7365
New Mexico
Yup, thats it, I have the same booklet
