gumbudah
Does anyone have any hard data on this one?
So I can see maybe two easy ways to do it. first check you gas meter, run your setup for maybe three days. write down the beginning time, gas meter reading, end time, and end gas meter reading. run the next three days trying it by turning the heat way down taking readings before and after.
Second would be adding some electronics. A recording induction ammeter would do the trick. clamp it on, note date and time. Run for 3 days turning the heat down, check readings, run for another three days without turning the heat down. You'd need to count the number of times the heater comes on, figure out how long the startup sequence is, and subtract the number of starts times startup time from the total duration for each method. This would give a total runtime which if you are running a fixed heat source (non modulating) should be a direct relationship to the quantity of gas used.
I been planning on doing something like this, but havn't made the time to get it done also, my wife now works from home so theres someone here every day... however she'll be out of town for quite a while so I should have an opportunity to check the readings using metod 1.
