heated concrete floor
rigsboo
as of right now all I have Is gravel down in my garage (concrete is coming!) but im thinking abut heating the floor any ideas how to do this? cheap is the key!
Bondo
Greenfield, Maine
Ayuh,.... Extruded foam board, pex tubin', 'n steel to tie it all together,....
Ya won't be sorry ya did it right,.... ;)
pmilin
Colorado
Heating the floor and cheap don't go together. Heating the floor will have a large up front cost. When you say cheap are you talking about operating costs? Search around on here. This topic has been covered a bunch.
R
rigsboo
well I think I got it...I don't need the whole garage heated I just want under my car (so when im working on it) get 300ft of the pex tube and lay the insulation under it and run it to a tankless water heater you think a 4 gallon per minute would be ok for 300 foot of 3/4? I don't care if it taks a few minutes to warm up as long as it gets warm haha
kd3pc
Northern Neck
heating the floor will have fairly high - ongoing costs as well. It will cost money to heat the water/solution that circulates in the PEX, once installed - that no matter the fuel, unless you have a natural gas well in your backyard.
kd3pc
Northern Neck
not gonna do it..., electric but at 60 amps...and only does a few gallons a minute and only a few degrees delta from tap water temp...
it will be tough to heat only a portion of the slab, as the rest of the slab is going to act as a sink for the heat,
you really need a system, not some disparate pieces. Electric heat of water is pretty slow and quite pricey compared to other fuels.
R
rigsboo
well I thought I was onto something :l what do you recommend? any other ways to do it?
sublime68charger
SW Wisconsin
Go through the heat and ac part on this site there are a lot of great radiant system set ups shown in there
My garage floor is gravel right now and whèn I get ready for putting in radiant heat I'm going through that with fine tooth comb to learn about radiant systems
jaye944
GTA, Ontario, Canada
sorry to hijack,
but is it doable to have a heated floor, on a drive/walkway?
I'm thinking for winter, stop me having to shovel snow?
the drive way is asphalt?
cheers
R
rigsboo
sorry to hijack,
cheers
theres a older man near the town I live at and he has a heated driveway but hes pretty wealthy and with enough $ anythings possible
Bondo
Greenfield, Maine
sorry to hijack,
cheers
Ayuh,.... If yer willin' to replace the driveway, 'n walks with concrete, 'n to shovel money into yer boiler,...
Sure,.... No problem,....
mikeyr
Santa Barbara, CA
the idea of radiant heat in the garage would be to keep it on. Turning it on once in a while so you can work under the car wont work, the rest of the slab will be one big heat sink, unless you have a major big time boiler, I can easily see the section under the car getting warm in hours long after the job is done.
James-W
Southeastern Wisconsin
I agree, in-the-floor heat is wonderful but only if it is left on. If you turn the heat off, or turn the heat way down when you aren't working out there, it quickly loses its appeal.
