Heated vests
cvairwerks
Within hearing distance of Texas Motor Speedway
Anyone that works outside using a heated vest? Since I was down pretty sick a few years ago, I've had trouble staying warm when it gets below about 65F. Although we are mostly in hangars at work, there is quite a bit of time that we are exposed to outside temps up to the entire shift.
When we are moving around, it's not too bad, but when we are refueling, or working in a fuel tank, the hangar is open for long periods of time. Even bundled up, I can't stay warm, and there are times I can't get more than a few feet from a control console for more than a couple of minutes when running some tests. Normal work wear for me during the cooler part of the year, is long sleeves, lined jeans, a heavy sweatshirt, a medium to heavy weight jacket and gloves or mittens. Below about 40 and windy or wet, add Carhartt Arctic Extreme overalls, and I still can get cold.
I'd like to try a heated vest, so I'm not looking and feeling like the Sta-Puft Man while still trying to do my job.
I'm looking at a vest by Gobi, as it's the only manufacturer that I've found that has them in 4X...I wear a 54 jacket for reference... Anyone know of another brand that I should look at? Milwaukee only goes to a 3X, as do most others I've found.
Jazz1
Thunder Bay On.
A better base layer would be better option. In the temps you describe merino wool base layer, a fleece and windbreaker would be sufficient. Base layer makes a huge difference in staying warm without having to wear heavy bulky layers.
Hilltopmasonry
Several people I talk to highly recommended the Milwaukee stuff.
PedroEvo
Toronto
I use the Dewalt sweater under really cold temperatures and it does really well. Highly recommended no doubt.
joe_padavano
Northern VA
I've got a Dewalt heated hoodie and I love it. The only downside is that the battery is a substantial tumor on the left side of the jacket and frequently gets caught on things.
C
cvairwerks
Jazz: The only merino stuff that I can find that will fit is from Minus33 and it doesn't have any solid reviews. I'm a little hesitant to spend 90$ on a shirt that has to be air dried and has several reports of coming apart within a couple of washings. Got a possible source from someone else?
Hill and Joe: Dewalt and Milwaukee are out due to sizing...neither has a 4X
Lynden: I couldn't find a shirt that was bigger than a 2x.
Jazz1
Thunder Bay On.
My HH set is 4 years old and worn constantly. It wicks which is important for extreme activities. Machine wash and dry. You get what you pay for. I spend all day snowboarding in -20C and colder temps.
https://www.sportchek.ca/product/he...wE&gclsrc=aw.ds#332357282[color]=332357282_01
I'm sure the name brand battery powered clothing is excellent if you have access to recharge facility. Likely more suitable to people who have sedentary jobs or possibly ice fishing.
22george
SW Ohio
Try a polypropylene shirt against your skin. Also do you wear a hat-stocking cap-and hood. I found that made a huge difference for me working out on the ramp in the winter in ohio.
Pen & Wrench
Huron, SD
It is a great idea. I use Warm-N-Safe heated gear on my motorcycle. I can go 70 mph in 27 degrees and be totally comfortable. The heated jackets are not bulky. If you can wear the jacket with something over it, that will help keep the heat in and make contact with your skin, you can dial in the heat to fit the situation. I'm considering a battery jacket, like Milwaukee or DeWalt for outside work when I don't want all the bulk. The the nice part of heated jackets, is that you do not need to bulk up with lots of layers, and you can adjust for more heat in the morning, and dial it down as the day warms up, and dial it back up towards the end of the day. If you get your wife or significant other one of these, you will be appreciated a lot more than you might think.
Bville-Bud
Shenandoah Valley VA
