Heater for garage
GMCGarage
Im looking for a electric in wall heater or wall mount for my garage. Just something to take the chill out, help melt snow on the cars, etc. I have a 20 amp circuit that I can use.
Anyone got a good suggestion?
kelpaso1
MEMBER EMERITUS
New Brunswick
Get a minisplit. Way more efficient. My 12K BTU is on a 20 amp circut. Estimate it uses about $30/month in electricity in the cold winters here. I keep my 22x24 heated all the time.
Loose Nut Buster
Near my house in Houghton Lake MI
I find a 30k tank top radiant propane heater to be quite effective and use it in my 26x36 garage to bring it up to 40° quite quickly. However it/they do not operate with a thermostat.
I have mine plumbed from a 100# tank outside and connected inside via a hose to locate it to an area where I'm working until the garage warms some in severe cold temps. The torpedo style can be stat controlled but are loud IMO.
Sent from my SM-T387V using Tapatalk
u2slow
BC
If its 120V... any 1500W heater of your choice. Or, if you can find a heater with a 900-1000W output (or mode switch), you can possibly run two.
If its 240V... a couple cheap/used (free?) baseboard heaters and some kind of fan are likely your best bang for buck. You could have up to 3800W of heat that way.
Garagefffreak
IL
If you decide to use some sort of a split system make sure that the outside temperature is within its operating range.. :)
Loose Nut Buster
Think _safety & insurance_, propane is highly explosive and the vapors are heavy, also if its heated with any open flame source down lows, this why most garage heaters are suspended from the ceiling.
u2slow
BC
Also heat pumps are far more efficient than resistance heaters.
Tough to beat 100% efficiency of resistance heat.
Heat pumps may consume less electric energy to heat your space though.... :thumbup:
MDJR3312
Wallingford, Ct
I have tried electric wall heaters in my New England garage and they never seem to warm it up enough for me. Still gets uncomfortable and cold. I just recently purchased a Ridgid propane heater (if you would consider a propane tank) from Home Depot. Now I can ware a tee shirt in my garage its so warm. I highly recommend it.
pcmeiners
"Tough to beat 100% efficiency of resistance heat."
Yes resistance heater turn basically all wattage into heat but heat pumps produce more heat per watt as they are only transferring heat from one area to another, not creating heat. Heat pump will supply 30-50% more heat per watt than resistance heaters
Play with this calculator to see the difference.
https://www.seerenergysavings.com/afue-savings-calculator/
u2slow
BC
Well aware of the cost difference. I'm highlighting the difference between energy-efficient and money-efficient. :beer:
