My ADP Cayenne (FOAP75) propane heater went into thumb twiddling mode last week after I turned off the thermostat for the day. (moved it from HEAT to OFF)
Normally when I do this, the fan will run for a short period of time after the gas is turned off - I figure to cool the heating pipes. Well I find out on Thursday, that the fan had been going since I turned it on.
The manual I have on the unit provides *zero* by way of troubleshooting information and Google searches have come up dry.
Can someone recommend what I can try to make this beast behave?
I've tried swapping out thermostats just in case and that didn't change the behavior. Setting the thermostat to HEAT doesn't seem to do anything either.
[edit: I should also note that the logic board's LED is blinking 4 times in sequence indicating a "High Limit or Rollout Switch" open" condition. Of course there's no description in the manual of what/where this device is....]
Help!
Thanks folks!
g.
Help!
Thanks folks!
g.
