Heater install speed bump.
my shops an all steel 40x60x16 and is only insulated by the 1/4" double bubble or whatever its called insulation. I use my shop mostly to keep my race car and daily drivers in, but I do often have some lengthy projects and work out there hours at a time. The last 3 years ive been using a very small craftsman forced air propane heater.This heater does the job but at 13-16.00 a bottle gets expensive. I recently was given a reznor heater from my place of employment due to they went full central heat and air.
Well myself knowing nothing ran a 3/4" PE line from my house meter to my shop (80') and was fixing to hook this heater up when i found out with my 1/4lb residential gas service the max btu i can run with the line i just ran is 70-75k btu. I know i should have looked into all this first. My heater is a reznor either 150 or 160k so its not going to work.
That being said what natural gas 60-65k btu heater would you guys recommend me to buy. im not going to keep the shop heated im just looking for something i can turn on say an hour before i start working and itll knock the chill off the shop. I live in central tennessee and most of our winters are mid to upper teens, we have on a couple occasions dipped into single digits. ill also have 3 ceiling fans to help circulate the air because ive learn in the past my heat is rising and itll be much warmer on the higher level as i was wiring somelights in once and it was a great difference ground level to ceiling level.
Thank you so much for your help
P
I tried to get my local gas supply company to do this or run me a new meter to my garage and I was told they only supplied one meter to each address and i was only allowed to tie in after the regulator.
P
I may look into this then. I see a lot of negative reviews on here for the heaters northern tool sells. So I’m not sure what to go with.
HoosierBuddy
Southern Indiana
You may be better off ditching the old reznor anyway. Likely oversized, and my experience with used hanging heaters (at least ones from the 1970's) is you really have to check the heat exhanger.....and when you do you may not like what you find.
So a new unit of the size recommended will probably work better for you.
If it was me, for a part time solution, I'd be looking at a modine hotdawg. For a full time solution I like the modine effinity line (high efficiency).
Phil
