Heater/lift wiring
Cody27
I currently have a 7500 watt heater in my garage. I wired it with 8/3 nmd90 on a 40amp breaker in my main 200amp panel in the house about 12 feet away.
I just installed a tmg tpl45 10k 2 post lift that requires a 30amp circuit. In this coming spring I will be doing a large garage addition, and during that time I will be adding a 100amp sub panel inside the garage.
My question is, can I wire a receptacle on the 8/3 and put a plug end on the heater and the lift and plug in whichever I am using at the time? The lift won't be used much, so I would unplug the heater and plug in the lift, use it then plug the heater back in.
Can I plug the lift into a recepticle on a 40amp breaker or do I need to run a new 10/3 30amp circuit? Otherwise downgrade to a 30amp breaker but I could only do that when the heater is no longer needed. Trying to avoid running a new line if possible. Thanks!
mm08822
Lift manual states 25A cb or fuses....probably just for startup inrush.
Since the lift motor will only be operated while under supervision, I think your plan with a receptacle is fine.
It would be a 50a recept as there are no 40s.
Also makes provision for a future welder.
BrandonV
Arizona
NEC would have you size the breaker to a maximum of what the manufacturer calls out for the lift and putting a cord on the heater if not called out (which I doubt) is also not code compliant.
Realistically? I'm sure people would be fine using a quality 3 HP NEMA 6-50/14-50 rated industrial receptacle and corresponding quality plugs with a 40A breaker.
mike93lx
Richmond, VA
The NMD90 means the OP is in the great white north.
OP, please add a location in your profile.
I'd do a 6-50 for this as well
C
Cody27
Haha yes sorry I am in Ontario, Canada. You don't require a permit or inspection to do any electrical on our side of the meter (if youre not hiring a licensed contractor) which is kind of scary but at the same time convenient at times.
C
Cody27
The lift does have it's own limit switch aswell. My main concern was whether or not I would be fine to plug it into a 40 amp circuit. I guess I could just add a disconnect switch inline on the lift post aswell.. code doesn't really matter as I dont require a permit or inspection here but would still be ideal to be compliant. This will all be removed when I do the shop addition and add the 100amp sub panel anyways.
LukeOresk
You’re supposed to get permits and Inspections for electrical work in Ontario.
You should have a disconnect on the lift incase you have to kill power to it.
