gj67stang
I've read countless articles/posts about heater sizing and ran the numbers several times through the online calculators, but I'd like one more confirmation on proper sizing before I make my final decision.
I am wrapping up the construction of a 40x60x13 pole building in north-central Ohio that will serve as my workshop. The exterior walls have housewrap, R19 fiberglass batts, vapor barrier and OSB while the ceiling is steel with R45 cellulose.
There will be a 600 sq ft (20x30) "tool room" in one corner which will house the majority of my tools, machines and equipment. The plan is to keep this at ~50 deg during the heating season and only bump it up during prolonged work sessions. For this task, a 50k BTU hanging propane heater should be sufficient (maybe the Mr. Heater Big Maxx?).
The remaining 1800 sq ft (L-shaped) will be used for truck, tractor, mower, material, etc. storage. I was thinking to heat this to ~40-45 deg with a 75-80k BTU hanging heater and bump up the thermostat during large projects out there and in the springtime to combat humidty/sweating.
Thoughts? Suggestions? Opinions? Ideas? Thanks!
