The Lazy Destroyer
Finally got my outbuilding insulated, it is approximately 41'x22' with 14' ceilings. I have R13 on the walls and R30 on the ceiling, both are fiberglass batts. Also have 3 of the HD 60" ceiling fans people post about on here occasionally. This is in GA by the way.
My budget to heat and cool the shop is at least another year out, so I have to deal with what I've got for now. I assume the proper way to heat it would be to get one of the Mr Heater type box heaters I see mounted to the ceiling. I believe they are vented propane or NG heaters? Maybe I can get something like that eventually but I have no gas in the garage and budget may not allow such a nice heater at the moment
Are there any recommendations to heat the shop if only temporarily for this coming winter or two? GA doesn't get too bad and this is the first winter with insulation in the shop... so I am not really sure what to expect as far as temps this year. Maybe I don't need much?
I imagine those 1500watt electric heaters probably are not going to cut it? The little I've read show those forced air propane units like this one might work but could introduce fumes and moisture, so probably not good? My neighbor has an old wood stove he's looking to get rid of, I guess I would need some type of special vent for it though?
As you can tell I'm pretty lost
And unfortunately I'm not really sure what the temps I should be expecting are. With no insulation on previous years, it's always closely matched what it was outside, but now... ???
I don't work out there all the time but would like to work out there on weekends if even just one day a weekend. So don't really need anything that will raise the temps super quick, maybe just something that can keep a little heat in. Thoughts?
