Heating a pole building
NUTTSGT
Northern Central Ohio
Door panels look good. I'm not sure how weight you are adding to the door but you may need to slightly adjust the springs on the door.
Are you worried about not having "direct" heat under the mezzanine ? I'd guess that is going to be a work area ?
bobj49f2
SE Wisconsin
Yes, the small amount of panels I installed on the smaller of the two doors have already affected the weight of the door enough that I'll have to either adjust the springs or get heavier ones. I was surprised on how they did. I wonder if the empty doors were so light and the springs might have been adjusted at the very lightest position and if there is a "window" of adjustment that I might be able to adjust within. If not, I guess I'll need new springs. Either way I need to insulate the doors.
I do have an a heavy duty electric heater that I had been using earlier this year to do some work in the shop. At that time I just set up a couple of cardboard walls to try to contain the heat and it seemed to work fairly decent when the temps were in the upper 40s. I might use that to supplement the heat from the main area or try to place a box fan on outside the mezzanine to push some heated air under it. Yes, that is the area where I plan to put my work bench, drilling table, drill press and other power tools.
finn
The UP, God's country
I would advise you to seriously consider upgrading your uninsulated doors to a light commercial grade insulated door. It will have better thermal properties than your home brew, and be much stiffer and up to the task. The springs and drums will be set up for the additional weight, so operation will be smoother over the doors lifespan.
You can recoup some of the cost of the upgrade by reselling your existing lightweight doors to someone looking for a door dou a storage building.
bobj49f2
SE Wisconsin
I have enough $$$ already in the insulation for the walls and ceiling, also the furnace. I ready numerous post here about garage door insulation and the posters seem to be happy with the kits you can buy off the shelf which are pretty much just styrofoam precut panels. The way I'm doing it I figure I'll be able to do both doors for around $200~, new insulated doors would cost close to $3k, not including instalation. I don't seem to have too much luck reselling items, I'd probably be lucky to get $200 for both doors. Too much hassle, just want the building done.
