Heating an intake manifold?
IROCZ
Do you think it would do any harm to an aluminum intake manifold if I heated it up to 500f for an hour? The reason I ask is I want to use a ceramic finish on it. Thanks!
kursplat
S.Cal
"The melting point of aluminum is 660.32 C, 1220.58 F or 933.47 k. Look here for more information: http://en.wikivisual.com/index.php/Aluminium"
sounds good to me. just don't turn the hose on it to cool it
Steve from Socal
Hutchinson Ks.
No the temp won't hurt it and a casting is not heat treated so you won't draw the temper out of it. Having said that; you want to ramp down the temp SLOWLY, after the cure time lower the oven temp to 400 for half hour, 300 and then 200. So the cooling time from 500 to 200 would be two hours. If you allow it to cool too quickly it may warp.
Steve
