Heating and Insulating a 40x40 Shop
79fordF2
Kentucky
I have a 40x40 metal pole barn with 12 foot ceilings. Looking for options on insulation and heat sources. Let me hear everybody’s ideas.
rok_hunter
home
My 30x40x12 in the FL panhandle has 2" of closed-cell foam all around and a MrCool DIY mini-split rated at 34k cooling/36k heating. Works great.
Shiftless
East Bay SFO
I insulated my 30x48x12 with 3" foam sheets and I heat it with a 40gal electric water heater.
Interesting.
Do you pump hot water into radiators or underfloor tubing or is the waste heat coming through the walls of the water heater enough to keep the building warm? What’s the temp inside now ? I assume your outside temps are maybe 30-50 degrees.
PWC Repair
Arkansas
Pics and info towards the end of my build thread in my sig. Been playing with it this year quite a bit just to see how far I can push it. I have 1200ft of pex in the concrete (6" thick). 1" foil backed styrofoam under the concrete. Even in the teens through the night and 20's during the day (about as cold as it gets here and never for long) I can keep the floor 58* and the shop will be about 52*. Then if I'm going to be working out there I'll kick on a fan coil that the water pumps through and it blows 90* air. I can bring the shop from 52* to 60* within a couple hours. Now,....if it's 40* or more outside, I can run the slab up to about 65* and the shop will stay 60-62*. Last year I didn't have the floor hooked up and heated the whole shop with just the hot water pumping through the fan coil. I used a programmable t-stat and kicked it back to 45* at night. Then staged it up 3* at 6am, another 3* at 7am, and another 3* at 8am. That would give rest in between for the WH to catch up. I really only have about HALF the BTU that the shop should require......but it works great and costs me hardly anything to run it. As a bonus...there is NO open ignition source with the heat. I can paint or spill gas and not worry about blowing up.
