Heating bathroom in unheated building.
Leaflessshadetree
Don't ask.
Getting started building a bathroom in an otherwise unheated building.
60 sq ft 8FT ceiling. All walls and ceiling will be insulated. Location is North central Illinois.
I'm thinking electric heat. (Propane is an option but the tank would be approx. 150ft away.
Any suggestions?
LB-1911
Northwestern Il.
Any suggestions?
The previously mentioned Cadet -
One example
Cadet CSC151TW Wall Heater, 120V 1500W Com-Pak Plus - White
https://www.westsidewholesale.com/cadet-csc151tw.html
yeldogt
The fan forced will work -- they are noisy IMO.
If you have 220v -- a simple line thermostat and floor strip heater will work very well. If it's got a shower ........ the 220 will bring it up to a nicer temp quickly.
Krist77
California
My sister in New Zealand just did a new heating. She has electric underfloor heating in her kitchen. She installed from here: http://fonko.co.nz/heat-pumps/maintenance/ it as she remodelled the kitchen two years ago. She wouldn't be without it now. One thing she advised me, was to put a spare thermostat wire under the tiles as they were being laid along side the primary one. The other end of the spare is redundant inside the control box on the wall. If the primary wire ever fails, instead of digging up the tiles, it can simply be open the control box and swap the wires over inside. It hasn't happened yet.
James-W
Southeastern Wisconsin
Voi
Western South Dakota
I'm going to heat our cabin's bathroom in the winter with a radiant cove heater I'm moving from my shop.
I believe the rule of thumb around here is 1 watt per cubic foot of room. So if you're in a similar climate that would be 480 watts or so.
http://www.radiantsystemsinc.com/
Marctrees
TX/LA border - Toledo Bend
bushmechanic
Get a towel warmer and a heated toilet seat. Chilly air will make them even more awesome. I keep it about 62 degrees in here, and there's nothing like grabbing a hot towel after stepping out of the shower.
Milton Shaw
I saw one house that had a natural gas fireplace in his bathroom. Wife did not want a plain electric wall heater. Turn fireplace on and it 5 minutes you didn't even need a towel to dry. Both bathrooms had a full length wall of cabinets with doors on both sides to restock from laundry room between them. Her bath had a whirlpool, shower and bidet. Very upscale house.
Bucko
Cheap and easy: a 500 watt permanently wired baseboard heater and a 240V line voltage thermostat. For a garage this is all I'd do.
This would be my first choice as long as it was not in like a woodshop with alot of sawdust circulating. Another option is a ceiling mount combo exhaust/heat, and light for under $200. The idiots that wired 2 of my bathrooms at my current house put the fan and heat on 1 switch. It was extra bathrooms I never used. Didnt realize until I fired up the exhaust while I was painting them. Luckily they have plugs each unit inside the housing so I was able to just unplug the heat. Dont need it in Florida anyway.
