Heating/Cooling shop
grabeb
880sqft garage with 19' vaulted ceiling attached to another 16x18 garage with maybe 12' ceiling height. Everything is mostly insulated and working to finish it off by this winter. Currently, I've been heating it with electric heat and I can fairly easily keep it 60+ in middle of South Central Kansas Winters. I also have a larger room window a/c that will cool the bigger garage some if I try. Debating if I go with a traditional Gas Furnace/AC or dual head DIY Minisplit system. I have a dual head mitsubishi mini on my 2nd floor of house, so I'm well versed in them, just not sure I want to spend the $8000-10,000 it would cost for similar system on garage. Friend installed a Mr Cool on his 40' class A and has been happy. With the traditional, I need to double check the line is still good, but I do have gas line from house to detached shop I ran 18yrs ago, so I should have gas at the ready. I have been told I could have a furnace that was undersized on another house, so it's only half dozen years old if that. I'd just need to get the condensor, which I might just have my houses swapped out for a multi stage unit and use that one. It's only a few years old.
I also have 200amp service to garage, so plenty of power and should have gas so my options are open. With the traditional setup, I would likely need to shift overhead door over a foot or two on my smaller garage, so I can stick the condensor away from my backyard patio. Not a huge task as the header is side to side, so it's an easy reframe.
I honestly, think the mini is the easiest and cleanest with least amount of work, but I've been told they aren't great in a shop due to dust. I try to keep things clean, but it is a shop and I do occaisionally do light woodwork, but I try to catch most with a small dust collection setup.
What have you all found?
G
grabeb
What about a DIY Mr. Cool mini split?
That would be my DIY mini option. Curious if good option or if central system better.
My main goal is to keep the garage above freezing in winter and comfortable in summer if I go out to work on something. I tend to keep it 50-60's in winter. If I can get it to 80's in summer that's find.
HoosierBuddy
Southern Indiana
If it was me, and AC was a priority, I'd go with the mini-split.
If you put a bunch of money into a garage/shop build....the HVAC system is not a huge % of the cost but can make a big difference not only in the comfort level of the space, but if you want to even be out there.
I was out in my (NON HVAC) barn Friday turning a small vase for my grand-daughter....and the proof of my love was the half gallon of sweat I lost while I was out there doing it. If it would have been for anyone else, I would have walked out there, felt the heat, turned around and went back into the house.
BTW...the barn is 80 years old and is uninsulated so no HVAC. My garage is fully insulated and I went with in floor heat with NG wall mounted boiler and a standard AC....but mini-splits weren't nearly as popular (or good) back in 2006 when I built it. But, when I built it that was the best HVAC system I could find.
So....buy once, cry once.
dcg9381
Austin, TX
DIY or your contractor installed? Either work. Many of us choose the mini because we can do the work ourselves. Around here it's 300% more to pay a contractor to do it.
I'd put an 18-24k unit in 900 sqft (OK to over BTU mini splits). Mr. Cool is the "consumer" brand that will have a warranty-ish. Pay attention to cold weather performance, in colder climates you need to move up to "hyperheat" units to keep them heating worth a darn below freezing....
They do have filters (for dust). Pretty sure you can pre-filter also.
You've got catchment system and could add a secondary filter for shop air if you wanted.
Yankeefarmer
Connecticut
Six years in, I’ve had great results from my Mr Cool Universal in my 1200 sq ft shop, primarily heating through the winter season and what little air conditioning is needed in the summer. If you search on my user name for my posts on the subject you’ll see I’ve posted ad nauseum, but provided lots of details so I won’t repeat them here. I used this system because I wanted control over air distribution and I wanted good filtration to protect the coils from the shop atmosphere.
racecougar
Missouri
Just over three years since installing it, I've been nothing but pleased with the Gree 24k unit I installed in my 30'x60'x13'. I do a lot of metalwork, but I run an air scrubber to assist in cleaning the air. Thus far, dust at the mini split head has not been an issue. Performance here in MO has been impressive, but my building is tight and well insulated (R-55 ceiling and R-19 walls).
zcar751
Knoxville, TN
To me it’s a math problem. Which is cheaper to run and what is the initial cost. I,m in East Tennessee and electric power is cheaper than gas so I have a mini split.
G
grabeb
I believe i have gas line, haven't tested it to measure sure it still is this. I definitely have power and that is likely the easiest route.
I need to look more into those 'hybrid' Mr cool diy systems.
pcmeiners
As to dust....
Without wood working it takes 5 minutes to clean the filters on my Fujitsu mini splits, remove filters, spray with Lysol tub and tile cleaner foam, rinse, reinstall. Once every year or two, clean the internal coils with PH safe coil cleaner, roughly 10-15 minutes.
With a great deal of dust fashion a filter made of cut up HVAC fiber filters mounted on the exterior of the min split, ugly but it will do the job.
fitter30
Peace Valley,mo
As to dust....
Citric acid is the first ingredient in Lysol. Can do damage to aluminum fins just saying
y'sguy
Tulsa, Oklahoma
The 12ft vaulted ceiling area may give you trouble with both heating and cooling. my art studio space is super well-insulated and tight. with 3 skylights on the north side. With a Mitsubishi mini-split. I forget which one. It will hardly make a difference in the heat we are having. I have the opposite issue in winter. It's maybe 5 years in service. I probably need to have it serviced, but nevertheless IF I had to do it over I would get a legit HVAC unit.
In the area attached , that is my 2-car garage, the mini split does a decent job This area is 30 x 30 with a 9-foot ceiling. I only run them as needed. Or don't go for a vaulted ceiling. Disappointed to say the least.
pcmeiners
Good reminder Fitter30 to watch which chemicals to use on coil fins.
Was not referring to use Lysol Tub and Tile @ foam on the fins, just the plastic filters.. According to the SDS it does not contain citric acid but there are safer PH neutral chemicals to use on aluminum fins..
Looked it up again ,the Lysol Toilet/ Basin cleaner has citric acid, the Lysol Tub and Tile@ foam does not..
fitter30
Peace Valley,mo
Have very rarely use coil cleaner of any type especially ones that brightens. The reason is every time its used just a little bit of fin thickness is lost till the fin as lost its strength and bends very easily.
