Ok, I've learned a lot searching here. I was going to buy a heating disk like this http://www.mrheater.com/productdetails_extended.asp?catid=42&id=21
But am now unsure. I understand it heats what is in front of it only. A light bulb type affect. But how FAR does it heat. I will be in a 8X12 foot portion of the garage. Would it do the job. FYI it is a small one car, uninsulated garage. I don't own it so don't want to spend on insulation. I did line the open portion of the rafters with plastic. And used can foam to fill the numerous leaks, though many especially around the large door exist.
I live in a cold area. Temps could be below zero at times. I will only be in the garage an hour or two at a time and will only heat during that time. I'm now leaning towards force air. I'd be very happy, if on a cold day I could get the temp in the low 40s.
Thanks in advance....
