muk
Here is my dilemma. I have a 5kw electric heater that I was given. I mounted it and put a double pole line voltage thermostat in line. the problem I am having is the Fan of the unit (which is 110v) runs all the time when the thermostat is in the on position regardless of temperature selected. The heating element is operating fine and only kicks on when it reaches the set temp. I have tried putting the fan power feed wire to the control side and it still runs all the time. I am assuming that it is getting power feed back. If this was a 12v system I would just put an appropriate diode in the system but with AC current I cannot do that. Does anyone have any ideas?
