ceramic artist
- Joined
- Feb 19, 2024
- Messages
- 8
I'm considering heating my garage with a SIR Sun Star tube. I'm wondering if any one has personal experience with this type of heater
I'm in Southern Utah (St George) near the Arizona Border. Elevation is about 2800' It gets surprisingly cold here. Fresh snow on the Mountains in AprilWhere are you?
How big is your garage?
How warm do you want the garage?
What do you plan on doing in the garage?
How often will you be doing this?
Will you be keeping it at temp, or raising it occasionally, as needed?
The manufacturer recommended the smallest tube heater SIR Sun Star Eclipse 25,000 BTU natural gas single stage. The entire assembly is 9'2" He said I will lose some BTU's due to the high elevation but felt it was more than adequate and recommended against going to a larger size.I'm in Southern Utah (St George) near the Arizona Border. Elevation is about 2800' It gets surprisingly cold here. Fresh snow on the Mountains in April
the ceiling is 12' high. Flat roof with 7" high Parapet. the garage is 18 x 30. I will be working with clay; the plan is at least 5 days or evenings out of the week.
I want it warm. Because it's so dry here, it always feels colder than it actually is. Working with cold wet clay is difficult.
I think it's best to keep it at some kind of warm temperature. At times when working on large pieces, I will be working on the concrete floor
until pieces can be transferred to a work table.
I have some concerns on how fast things will dry out which causes cracking.
Thank You
Can you give me more insight on needing "to be aware of keeping distances from stuff"Love mine. Look up radiant tube heater, lots of discussion on here. Most who have one love them.
You do need ceiling height, and have to be aware of keeping distances from stuff, but I really like how quiet it is and how efficient it is.
I have been up and down I-15 many times, back when I was driving truck.I'm in Southern Utah (St George) near the Arizona Border. Elevation is about 2800' It gets surprisingly cold here.
Just what was said above....the IR heats objects, so if you get stuff like cars too close it can cook them or their paint.Can you give me more insight on needing "to be aware of keeping distances from stuff"
Good suggestion Steve if I can figure out how to do itI have been up and down I-15 many times, back when I was driving truck.
I know the area. My sister lives 'next door' in Hurricane.
May I suggest adding your location to your profile? It can help with some general questions like this.
The Factory engineer thought moving up to 35 K would be too hot. The garage door is insulated but generally they are not air tight around the fringes.I installed this SIR35 around 14 years ago.... it has been very reliable and has done the job nicely.Back in the day I used to install Detroit Radiant and Dayton commercial versions of these heaters so I am very familiar with these type heaters. When I added on to my shop I bumped it up to 45K with factory parts.When I took it apart it was still as clean as new. Now it is a little louder and rattles a bit , but is stone cold reliable.I will say that the intensity of the heat is not the quite same after all these years...I need to call SunStar about that.I would say the height of the heater is very important to get some spread of the infrared heat.At around 11ft you should be fine...I question the 25K sizing, you may be underestimating the heat loss thru the overhead door. Ask the factory if you can convert 25K to 35K. You will LOVEthe feeling of the sun on your face!
4" away from the back/reflector yes, 4" in front of the tube HELL NO.The Factory engineer thought moving up to 35 K would be too hot. The garage door is insulated but generally they are not air tight around the fringes.
I don't know what is the right thing to do. He also said as far as damaging any surrounding areas was not a concern. He said you can have items 4" away and my ceiling height was more than adequate. I will have to move an overhead light in order to mount the tube in the center. Putting it on the wall would work but he said It would not give me the best coverage.
