Heavy duty truck brake spring remover
volvo92906
Northwest Ohio
It works well. I have a tool that is used on the big return spring. That also works well. However, if youre good at the screwdriver/pliers technique for the springs that works pretty good too. I still find myself doing it that way despite having an actual tool.
By the way, the OTC one is just as good as the Matco or Snap-On one. A friend of mine has the OTC version.
Here is the other one I was talking about... A big one for you guys here... MADE IN THE USA!
http://www.pbproducts.biz/
Stick
Alaska
The Matco one is just a rebranded OTC tool. You don't really need it at all though. Use a prybar to pry up on the brake shoe, and pop the roller out and away from the s-cam. To install new shoes, assemble them without the rollers, pry up on the shoes, and install the rollers/retaining spring. Just as easy, and I'm sure you already own prybars... ;)
kmkalf
Buffalo, NY
i put a pair of vise grips on the springs and with a prybar as leverage pull down or push up depending on abs sensor or not and remove the spring. than you can do it the same way to reinstall or use an awl or hook to put near the hole and push the spring back in. can r&r brake assemblies in about a min or so if wheels/drums are off
nathan_454
Centralia, WA
large screwdriver with a groove ground in the side of it - about 3/8" from the tip works fine for me. been doing it this way for 10 years. Once in a great while a pair of vise grips comes into play.
sdguy55
Pierre, SD
Sounds simple that way. And it would be but I have tried on various different ones and all the ones I have done you still have to stretch the springs a good ways to get it to hook. I bought a snapon tool that's got a groove cut into the tip of a prybar that is suppose to make it easier to install but I have not had to do brakes since I have gotten it. Go.figure
peterbilt89
Cumberland plateau, Hills of Tennessee
Thats the s easiest way
Cedge
Greenville SC
Peterbuilt
Pretty much SOP in our shop for 30 years. A decent tool for removing those frozen pivot pins... now that would excite a few mechanics... LOL
clueless
small northeastern pa town.
got the matco one, see they went up in price a bit since i bought it in 08,but the otc one is the same,snapon is the same, find the cheapest one and buy it.
ive done the vice gip/prybar,found this works somewhat better,doesnt slip off the springs.
V
_vin_
That looks interesting. Could you take a picture of the working end?
V
_vin_
Have you had to warranty it?
Loudpipes66
Southwest PA
Tooltopia recently had the OTC version on sale for around $56 if I remember correctly. Great tool and made in the USA. Works great on Q-plus but not as good on ES-II.
truckdriver
Miami,OK
I only work on my own truck, but have always used prybar/vise grips. I love to buy new tools but never saw the use in buying the specialized tools when I can do it in about 30 sec this way.
stephen4785
Benbrook, TX
This.
I always chuckled at those prybar spring tools. Just remove the rollers and lift the bottom shoe up then grab the spring by hand.
Stick
Alaska
Peterbuilt
They make presses for doing them. Simar to a ball joint press, and you can remove/install the bushings as well. I know Tiger Tool makes one, and I'm pretty sure Snap-On has one as well for anchor pins.
otis66
This.
This is what I do. That Matco tool is a waste of money. I have the OTC version that just collects dust in my tool box.
