Placeholder17
Finished cleaning up this find from a garage of a friend of a family member was was retiring and fleeing south to a warmer climate, abandoning much of his accumulated "junk".
These are 1950's hedge trimmers that are a rather outdated configuration, with a switch on the cord instead of a trigger and blades that only cut on one side.
However, a few interesting features (uncertain how useful as I've never used hedge trimmers before) are:
The guts of it are:
It was missing a switch when I got it and the cord was disintegrating. I replaced the cord and added a lamp switch on the cord.
The motor is a little baby, only rated for 1.2 amps. After the restoration, it draws 0.85 amps no load, but did great cutting a random evergreen bush in my yard.
- The handle can be spun and re-attached in 90 degree increments.
- The blades can rotate 360 degrees and are locked at any position by a set screw.
The guts of it are:
- Ball bearing on front of rotor in gearbox, bronze bushing with felt wick in rear of rotor
- Steel worm gear screwed onto rotor shaft
- Brass bull gear in gearbox driving a cam shaft sitting in a pair of bronze bushings
