multiscepter
- Joined
- Oct 19, 2014
- Messages
- 5
Hello All,
Fairly new to this forum, as I expected there is a wealth of knowledge amongst you all that I hope to absorb. At this point all I have to offer are things not to do. Joined after purchasing a HW 4-Ton, I know should have done it the other way around. Anyway I purchased a 4 Ton jack, from an overhead view all looked good, was a bit sluggish on the lift but improved after following the tips outlined by "Hiball" and others. There appeared to be quite a bit of sludge in the fill port so despite it functioning better I decided to proceed with a tear down, figured if there was sludge in the fill port there could be more downstream. On the bottom side of the Ram I noticed pitting, my guess is that a previous owner left it extended and moisture got to it, just a guess. Also the Ram packing crumbled to the touch and a number of the other seals were stiffer than expected. I've picked three of many photos already taken; Overall, a Pitted Ram, and the Reservoir Tube with Sludge.
So, the first of many Jack questions to come. Is a pitted Ram beyond repair? I would imagine the unit would leak when the pitted portion of the Ram crossed the packing. Is this something I could live with or is it best to look for another Ram. Any recommendations for purchasing a Ram? Other than sludge everything else looks pretty good, the pistons look especially clean. Thank you.
