Hein Werner 4 ton rebuild
wsurf4me
I picked up an old Hein Werner 4 ton model GG, the ram is leaking pretty bad. Any advice on rebuild or a rebuild kit?
W
wsurf4me
So I ordered a rebuild kit however the ram seal nut is buggered up. Looks like someone took a chisel to it instead of a spanner wrench. Does anyone sell parts for these other than the repair kits? How tight does the ram seal nut need to be?
469 runner
North Carolina
Those nuts are tightened to about 400-500 lbs/ft I believe. They use no gasket between the parts. Hard parts are not available generally, though I have run across a few items on e-bay and a local hydraulic shop. Parts the these are not being made, it is old stock. Good Luck.
TracField
Any chance of building a copy of or refaceing the tank nut at a machine shop? Not cheap I bet,but not a lost cause either for good equipment.Some of these parts are partly based on off the shelf components,NPT thread,pipe.Bad idea? I also once wanted some glass Japanese,turquoise colored fish net floats.I have some of the bottles they used to get the glass from,but the glass worker said I would be better off just buying the original off Ebay,and I get to keep my Japanese wine bottles.
http://www.manta.com/c/mx2my1b/hydraulic-jack-repair-by-diesel-mania
Used parts advertised .Restorations.
