Gslocum
Long story short: I ordered a HW93642 from Jackxchange.com a few days ago and it was delivered by UPS today. I assembled it after it arrived but I have a few concerns.
Box had a hole on the side - base took a slight impact in transit, but it only chipped the paint a bit.
I bled the jack and added a bit of hydraulic jack oil as recommended by the manufacturer until the oil level was 3/16 above the inner cylinder.
However, I noticed that this jack doesn't seem to engage the cylinder until the handle is nearly 30degrees from the floor, making for many, very short pump strokes to lift a vehicle. Is this common to this style jack? Every other floor jack I've used is capable of lifting from nearly any handle angle. In a tight garage, this makes lifting my vehicles almost impossible unless i have 6 clear feet on either side of my lifting point.
This is the point on the downstroke where it begins to lift:
Also, every ad I've seen for this jack notes a "one piece handle" yet it arrives as 2 pieces. It uses a small bolt to combine the two pieces, but the result is a top handle that clumsily flops around, swaying almost 10 degrees from side to side. I've never seen such poor build quality in a handle before, and it surely can be safe this way, can it?
Shirt vid showing the slop in the handle:
http://www.youtube.com/watch?v=tMU96f7Sxhw
I'd like to know your opinions before I contact the MFG and the retailer.
Thank you so much for your help.
Gabriel Slocum
Gabriel Slocum
