frijolee
Wanted to chime in with a post regarding my experience with Legacy Industrial’s “Hellfire” polyurea floor coating.
I got turned onto the product after finding the review section over at “All Garage Floors.” The editors over there are pretty specific that the newish single-part polyurea coatings (which hit the market around 2015) are their favorite coatings for DIY folks.
https://allgaragefloors.com/polyurea-best-garage-floor-coating-kits/
Hellfire is a newer product, but I liked what I was reading especially in terms of heat resistance (no hot tire pickup ever, probably handles grinding and weld slag better)
https://allgaragefloors.com/hellfire-floor-coating-review/
This is my second garage coating effort having done an acid stain floor back in Southern California that turned out really well:
If you’re curious there’s a similarly detailed write up on that process here: https://www.garagejournal.com/forum/showthread.php?t=285957 the acid stain bits starts in post 10.
These days I’d probably be looking at straight stain rather than acid stain, however my new place needs something intended for abuse and Hellfire looked to meet that need.
Bottom line up front: Legacy Industrial is a great establishment--my very positive experience with the first floor was part of why I went back to them--customer service is on point, and thus far I like Hellfire as a floor coating product a great deal. It’s goes on easy, it’s damn tough, and far more forgiving than a “fancy floor” so I find I don’t have to think about it.
The space: ~2100 square feet of garage, workshop, and concrete-floored garden room on 3 acres of the Big Island, Hawaii. Eventually I plan to try out Hellfire as metal coating substrate as well since I have some left.
Starting points…
Garage (640 sq ft):
Workshop (1350 sq ft):
Garden room (maybe 100 sq ft behind the garage).
This is country living so the floor is gonna get used hard.
--Chemicals: I have three project cars: a widebody v8 powered rx7, a long arm Jeep XJ, and a Toyota FJ40 rock crawler on 41s that I’m building up slowly. There are definitely some oil leaks that this floor needs to handle. I’ll try to keep brake fluid off it (because I’m not an idiot who needs to push my luck, regardless of the claims)
--UV. The Big Island contains the southern most tip of the USA. The air is perfect (I work on big telescopes as my day job) so the tropical sun is going to give this a workout with some exposed thresholds peaking out under roll up doors at both ends.
--Abrasion: Portions of the driveway were once gravel, now pretty much dirt. So I’ll be tracking in mud and rocks with some degree of regularity. I also do machine work so this floor is going to get covered in metal shavings and the like.
--Weld slag. The FJ40 is still getting welded on plenty so we’ll see how this stands up to some heat.
By the way, my wife and I are new owners of this home, so this all needed to go down in the midst of moving week since I was in the process of surrendering a rental home. The clock’s ticking and I need this floor dry enough to move some heavy equipment across it in very short order.
There’s also some serious prep work to do… The shop once had paint booth in the corner and it’s got old nasty paint flaking up damn near 1/8” thick in places. It’s filthy dirty from being used as a wood shop and also covered in skid steer tracks from heavy equipment rolling in and out.
Let’s do this thing!
-Joel Payne
PS: the project’s all done but I’ll be documenting the prep, use, and results over the next week or so…
Starting points…
Garage (640 sq ft):
-Joel Payne
Once it was partly grown out (3.5 weeks in?), I finally took one of my wife’s emery boards and was able to shave off what was left. Good times, and good times in an awesome garage ahead.
