Hello from Arkansas!
CPTpatt
I have a new structure on the property and would like some advice/suggestions.
20x22 w/11x22 lean-to.
9x7 insulated garage door
2x4 studs 24" OC.
Trusses are 24"
Metal siding and roof (no sheathing)
Double bubble foil was placed between trusses and roofing. Not on walls.
I am thinking about installing staple tab bubble foil then batt insulation between the studs before I run electric. I know we should have used sheathing and house wrap or the Zip panels, but we didn't.
The usage we be a mix of storage and workshop. Not designed to be anything extravagant. Any thoughts on insulating the walls would be appreciated.
nadogail
Coronado, CA
There will always be arguments about what kind and thickness is best, everybody agrees that any insulation is better than no insulation.
