Dust2dust02
Hello all, I am a first time poster here. Looking for some insight. I recently bought a garage for the first time. The house was always inconsequential. Been doing little things here and there throughout the house, like burning out the bus bar with a welder... You know, that kind of stuff. While the electricians were in and out of the garage 1000 times in the 2 weeks it took them to fix it, the garage door started screeching. I have already done everything I can to lower the horrendous noise. New rollers, isolation mounts, lubrocity and now I make it to the dreaded sheave pulleys. The bearing is apparently going out and it needs to be replaced.
I have 3 issues.
The issue of actually getting to this thing.
The issue of replacing it with another sheave that will fail.
The issue of how much torque these things seem to be under.
Issue 1 I resolved by some careful twisting.
Issue 2 was resolved by getting a 5inch cast iron pulley with actual bearings in it.
Issue 3 I made better by putting a huge *** C channel up against it. I will post that picture later.
My main question for you all is, I googled the heck out of this thing. I found out it is a
Low headroom rear mount spring setup. I found out those pulleys are called sheaves. What I could find NO mention of whatsoever, is the twisting! No one has this problem? Do you and just don't care about it? Please help! I am worried this thing is going to come off and slap around all over my garage.
Thanks!!
I have 3 issues.
Thanks!!
