Hoopy Frood
I'm very new to welding and have a very limited setup to work with. I'm a homesteader just trying to learn the basics. My lack of skill is definitely a large portion of the problems I'm having. But I'm REALLY struggling to maintain my arc; more so than I think my skill limitations should allow.
18 months ago I took a ~20 course class that used 6011 a bunch but always on nice Inverter machines running DCEP. I struggled with arc length and rod sticking then, too, but not ANYWHERE near as hard as I am now.
This is my first time welding with AC. My buzzbox is a 1991 Crafstman "Infinite Amp Arc Welder." It's model number is (as far as I can tell with a torn sticker) 110-1039919. The name will get you an image of the box on a Google image search. But the model number gives no results on a Google search at all. It was a gift from a friend (an unwanted hand-me-down from his dad). It's a 240V box. Maximum setting is 230 amps at "20% Duty Cycle." "100% duty cycle" tapers off at anything over 130 amps. I'm afraid I don't know what that means but will do research if needed.
I'm using 1/8" 6011 rods (Harbor Freight "Vulcan" rods) on 1/4 inch C-channel for practice. My practice bead pads are horrible. The major factor in the awfulness is maintaining the arc...
When I successfully maintain arc, the beads are "acceptable", given my lack of skill. But 90% of the time I can't maintain an arc for more than 2-4 seconds. Every time the arc goes out I fight slag inclusions, and the beads can be either cratered out or piled up.
Every 6011 video I watch shows a very strong, robust arc. Since I struggled so hard initially, I have since then spent about six hours over two days running pad after pad while slowly increasing the amps trying to get a stable arc before entering "too hot" territory.
As far as I can tell the arc is every bit as hard to maintain in "too hot" conditions as it is in "too cold" conditions. My lack of skill is a factor in this, sure - BUT - it seems if I pull the electrode any (and I mean ANY) distance off the surface of the puddle the arc goes out immediately.
I've been pre-grinding surfaces to moderately clean them up. I have intentionally not been fastidious in my prep. Part of 6011 use is that it SHOULD work in dirty conditions. I cleaned practice surfaces to better-than-mill-scale but no more for most tests. However failing so hard, out of desperation I have also tried to practice with VERY cleanly-ground surfaces and also with cruddy, rusty surfaces. All surfaces, regardless of prep work, weld the same: the arc is VERY difficult to maintain.
Current settings: The HF "Vulcan" rods are rated only to 120 amps. They were inexpensive and well reviewed, so I picked up a few pounds. I was very surprised to see them rated to only 120 amps after I got them home...
Initially I was sticking them like nothing else at any current, including 120 amps... Per common advise I increased current. The sticking continued at 130 amps where my welder drops below "100% duty cycle" (see attached pic). I may be bad, but I'm not THAT bad...
According to the current selection handle I got best performance at about what would be labeled as 150 amps (again see attached picture). I welded quite about bit at 160-170 amps on the gauge but the arc would still go out at the drop of a hat; I estimate at 1-2mm above the puddle even at that high current it would extinguish instantly. However that was definitely too hot for the electrode... the flux discolored along the entire rod in short order.
The only way I could keep the arc going - regardless of current setting - was to keep the electrode right on the surface of the puddle. ANY hiccup resulting in that 1-2 mm gap between puddle and electrode would kill the arc immediately. I do not remember my DC welding in the class being even 10% as temperamental as what I've been dealing with the past couple days.
Again, I'm bad, but I don't think I'm THAT bad. Could there be an equipment issue I'm not aware of? I've heard an AC arc is harder to maintain than a DC arc. But this is ridiculous.
I filed the jaws on the the return connection clamp to make sure they were super clean (and ground clean the connection point for the return clamp on each work piece) every time, so that was not an issue.
Any thoughts or suggestions? I'll keep knuckling down. But I feel something is amiss that my n00bness is ignorant of.
Thank you in advance for any help you can offer! I promise (actually just plain hope) I'm not a lost cause
