So I'm a relative newcomer to Garage Journal, having finally gotten my first garage a couple months ago. When we bought the place, the previous owner noted that there was no 240V supplied to the garage and I took that at face value. However, while taking a look at things the other day I noticed that it seems that the garage actually does have a 240V feed but it's only been effectively used as a pair of 120V feeds.
Here's the house panel - the garage circuit is the pair of 40A breakers at top left of the panel under the main 100A breakers. The panel and breaker arrangement appears to be such that each of the two 40A breakers supplying the garage are from opposite legs of the main house feed. Outgoing wire to the garage is 8/3.
And here's the panel in the shop - as far as I can tell, each leg of the feed from the house is being used to supply one leg of the subpanel, but they are never used to create a 240V circuit.
So my question is, considering the power arrangement, is it possible to (via the existing hardware or by installing a different subpanel that allows it) to get a 240V circuit working and still retain the 120V circuits already installed? Or would I need to have another feed line and subpanel installed for a dedicated 240V circuit? It would need to support a small TIG welder, which would be the goal of the exercise.
Keep in mind that I only know enough about wiring to get myself in trouble, I'm only looking to know whether this is possible and I'd be getting a professional to do any installation.
