u118224
A friend gave me a 20 ton bottle Jack that doesn't work. I took it apart, put new oil in and I can't figure out why the ram won't raise with the pump. I drained the oil back out. The ram raises with air at the closure valve port, and it raises with air at the pump port if the closure valve is close. I removed the pump and it seems to make air when I hold my thumb over the end and pump it. The check valve appears to work as well. Any thoughts? I'll try to post some pics.
