Help: Broken Tap in Flight Hardware
KnurledNut
n/a
If nothing else, maybe the tool manufacturers reading this will recognize an empty void in the tool industry, micro tap extraction tools.
Toold_up
Attached
He’s been a member since 2011, with only 368 posts. Guess GJ isn’t his first passion / time sink like so many of us.
I don't know, posting in an online forum asking for help to extract a broken tap in some spaceship part... 🤔
Sure, it's possible.
cherrybomb
Near Madison Wi.
Use a 6” or so piece of flat steel for a handle. Find 2 small drill bits to fit in the gaps between the flutes. Use vise grips to clamp the bits to the bar with the proper spacing, in the middle with the bits perpendicular to the bar and sticking out enough to reach down into the flutes. Use oil.
Would allen wrenches substituted for the drill bits work like you suggested?
Cc_windsurfer
SB, ca
Well, I broke a 6-32 tap today. Blind hole below the surface in 6061 Al. My small broken tap extractor is broken as well🤔
Beowulf
Just wanted to let everyone know, we were able to get the tap out. We had to make a custom tool. Basically we took a 256 tap with a collar over it that pinched too tiny tongues of metal in the two flute grooves. Then we epoxy that into place, and probably with only a 16th of the tongue protrusion, we were able to get it into the flutes of the stuck tap and slowly work it
jrevans
Glad you got it out. Was spitballing this as I read through the thread, was considering a staple from a common desktop stapler, folded in half and inserted between the flutes.
I work on spaceflight ground support equipment, the rules are substantial, but it isn't flight hardware.
Beowulf
Yeah, the rules are nuts. It makes for some fun challenges, but the paperwork sure slows it down.
Bob K
ex-Yugoslavia
Here is an idea how to make this miniscule tool DIY. Two sewing needles fixed side by side with two small rectangular aluminium (titanium) plates. The plates are clamped together with four machine screws. As you assemble the tool, clamp it in a vise so the needles leave an imprint on the inside of the plates (bed themselves in). Those needles are tapered tips and pretty tough steel. Photo showing two sewing needles next to 1.5 mm drill bit. broken_2_flute_tap_key.PNG2024-01-30_041943.png
mechcsu
Likely a no go for this situation but I figured I would share this trick I have used before. A broken tap that is wedged into gummy non-ferrous material can be removed with the help of acid. The acid will partially dissolve the steel tap to the point that it can be backed out. The trick is to know someone good with chemistry who can help you select an acid compatible (or nearly compatible) with the base material and its alloying elements but yet able to attack the iron in the steel tap. Once the broken tap is removed remember to neutralize any residual acid.
