Help Cleanup Transmission Fluid staining Garage Floor.
JohnMcD348
Lakeland, FL
Apparently, somebody placed lot of junk right on top of 2 full jugs of my Chrysler transmission fluid all over the concrete floor in the garage.
It's pretty well soaked into the floor. Is there anything that can clean this? Or, is it just something I have to learn to live with?
Thanks for the input.
RPH
Michigan Thumb
Start with powder detergent for clothes. Pour it on and grind it in with your foot. Make sure you have a heavy coating and let it sit. It will draw quite a bit out. Grind with foot every so often.
rsanter
visalia ca
I like using the orange hand cleaner and a stiff bristle brush.
Scrub, let sit, rinse, scrub, rinse....repeat
Bob
Greased Lightening, straight. Rub in with push broom. Don't waste time scrubbing hard. Let dry over night (if the area is in bright sunshine, wait until the sun moves so that it does not dry out too quick). Rinse with a garden hose. Let dry and repeat if necessary.
Lelandwelds
Central Texas
Used to use stuff like pet ether, ethyl chloride and 1-1-triclor and stuff that actually worked. Today?
Detergents, isopropyl alcohol, finally acetone . Rinse and repeat each step. Bentonite powder pull lots of things from concrete. Some of the microbes used for oil spills work . Hot water pressure sprayer. Emulsifiers like hand cleaner. D-limonene. TSP. Borax.
The stain will wick up again. Repeat whatever worked the first time.
Daves69
Kernersville, N.C.
After doing this make up a paste with the detergent and automatic dishwasher powder and water then let it dry. This will draw out the oil.
