I have Bel Aire 318VL, 7.5hp motor. I wired it into a welding outlet in my garage with a standard plug end on it.
The problem is, it only charges to 25psi when I turn it on and let it run for 10 minutes. It charges steadily and stops at 25 (I verified the reading with a separate gauge).
I took the air filter cover off and felt to see if air was moving out while the unit was running but this did not appear to be the case.
I'm at a loss on this, I bought it from a body shop that had it wired in line with another identical unit (everything was fine while installed at the body shop).
I had to change the wiring to get it to start up in my garage, if somebody has an idea, I would greatly appreciate the help.
Thanks guys.
Thanks guys.
