I want to build a 20x18 covered patio and getting confused with different answers.
i want to use 6 posts and span the 18’ ends.
can I use 6x6 posts, beams and ridge support?
Do I need a ridge beam or can I use like a 2x8 ridge board with 2x6 rafters?
I don’t want to span the middle 18’ posts, just the ends, is this possible with ridge board?
Is 6x6 good for the spans and posts?
Hopefully you can help!
*Edit-7/23/2021
ok, if I simplify this and put in 4 more posts on 18’ span with 10ft max span between 2 new ones and 4ft between corner posts.
can I use 6x6x10 beams on end and not the middle one? Or if I need a center span can I use (2) 2x12x18 in center?
can I use 2x6 rafters?
as far as ridge can I just use a ridge board 2x8 spanning the 20’? Or will it need center support or do I need ridge beam?
*Edit-7/23/2021
